Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2008-03-11, 05:44 PM   #1
trim_it_up
trim_it_up is infamous around these parts
Cool Ref. Arrows
So I went and took a little course on Autocad Electrical 08' and the whole nine yards. And although I know for a fact you CAN assign your own custom reference arrows...I cant find any literature on the subject. I've tried several approaches:
wblocking my design
modifying Autocad's preset arrows
and attempted to put a symbol a folder by itself and adding it to the search path.
I would just make a block and keep inserting it, but I want my conduit schedule to be flawless. Taking shortcuts like that on a program like this almost defeats the purpose of using it in the first place. If anyone could give me detailed instructions on how to assign your own custom arrows it would be most appreciated and maybe I can return the favor!
HXC
trim_it_up is offline   Reply With Quote
Old 2008-03-11, 08:07 PM   #2
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
Default Re: Ref. Arrows
HXC
Welcome to AUGI. Thanks for looking us up and asking questions.
This is where I get my information on what topics are needed for ATP classes.
It sounds like you were on the right tack about modifying AutoCAD’s arrow. For future, copy them into a template file or store a back up set.
Here is a word document that I hope will help. If you need me to make a more in-depth step-by-step, let me know.
Always help to help!
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Old 2008-03-12, 03:12 PM   #3
trim_it_up
Cool Re: Ref. Arrows
So I followed your instruction (which was awesome) and I got the arrows to start working..but now, only the source arrow on page 3 where the arrow points to the right horizonally is of a different style! I cant figure out how this happened, or why it's only happening on page 3. I checked into my project/drawing settings to make sure that they all had the same style selected and they do. I'm going to be attempting to work around this all day so if anyone has had a similar problem.....HELP!
Old 2008-03-12, 11:19 PM   #4
trim_it_up
I still have not solved this issue but as I see a few of you are reading so I'll update the problem. Now I've copied my project settings and started a new set of drawings. The problem from above is now repeatable on this project as well! :[ for some reason every page 3 that I use has corrupt reference arrows...but only in one instance. the source arrow on the right side of a horizontal wire. They are just the wrong reference arrow. BUT! the problem is only consistent on page 3. I cant reproduce the issue anywhere else. Does anyone know a way around this? I'm totally perplexed.
Old 2008-03-13, 01:44 PM   #5
RenataP
RenataP's Avatar
Interesting. If it is possible, please attach two drawings, one being 3 and the other being a sheet which 3 references. I will attempt to dive into the problem. Puzzles, what great fun! We might have to read some of the hidden data stored in the drawing.
It is by helping others that I get a greater understanding, so thank you for asking for help.
You asked for a way around the problem...you should be able to swap out the wrong arrow for the current one. Have you used the swap block before? Here are some snap shots.
__________________
AU - 2008
Last edited by RenataP : 2008-03-13 at 02:26 PM. Reason: adding away around problem
Old 2008-03-13, 08:27 PM   #6
trim_it_up
I've cliped on two pages for you. If you could, when you've found this problem let me know how it came to be. Like I said, I've been crunching on this thing for days and cant figure it out...but I'm not what you would call a seasoned vet at the Electrical version. Thanks again for all of your help RenataP, you truly are a saint.
=D
hxc
Old 2008-03-13, 10:52 PM   #7
RenataP
RenataP's Avatar
Ok, spent some time and attached is my solution.
Hope this helps for the next project.
Keep in mind for next time to name the new blocks with 6 or 7--9 [HA6S1] as those are set aside from Autodesk for users to customize with keeping originals.
Have a great day!
__________________
AU - 2008
Old 2008-03-17, 05:18 PM   #8
trim_it_up
RenataP, thanks for all of your help. Not only was I able to fix my problem, but now I have a much greater understanding of ACE. Since I got the time to fix this little mix up I also did a little exploring and fully understand how the problem came to be so hopefully I can pass the knowledge on to my fellow co-workers. Thanks again for all of your help.
=D
hxc
Old 2008-03-17, 06:34 PM   #9
RenataP
RenataP's Avatar
So happy I could help! Digging into ACE is a nice pass time for me.
__________________
AU - 2008
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Arrows Arrows - too many Arrows! (ELEC) sparkie001 Revit MEP - Wishlist 4 2007-08-14 03:30 AM
Can you have an X-Ref inside of an X-Ref? smooth shoes AutoCAD General 3 2006-11-29 03:50 PM
Arrows (once again) WolffG Revit Architecture - General 3 2006-07-13 03:45 AM
Ref planes vs. ref lines - when to use which... 4christo4 Revit Architecture - Families 5 2006-03-22 09:59 PM
Stair arrows patricks Revit Architecture - General 11 2005-08-11 09:01 AM
