How do you guys handle the walls in revit. I having so many problems wiht each single method that I've tried.
1. I have built the walls from foundation to parapet. I hd problems trying to keep finish layer of the wall from foudation to parapet when its only need it inside occupade spaces.
2. I had problems if I built segmented walls from foundation to first floor, then to second floor and then from roof to top of parapet. If I don't constrain every wall then if I move something on one floor I up end with off walls on the rest of the levels.
3. I heard that one way to do this right is draw two walls one for the block wall and other for the finishes. Is that a right practice or its too complicated.
I would appreciate any feed back that I can get from you guys.
Thanks
