Tuesday, February 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > AEC > Revit > Revit Architecture Support > Revit Architecture - Families
 Welcome, Guest.
Login
Revit Architecture - Families Topics about creating Revit families.
Reply
Thread Tools Display Modes
Old 2008-03-21, 05:35 PM   #1
jsteinhauer
jsteinhauer's Avatar
jsteinhauer is going the right wayjsteinhauer is going the right wayjsteinhauer is going the right wayjsteinhauer is going the right wayjsteinhauer is going the right way
Question Text doesn't like moving in two directions
Hi All,
I have another annoyance I can't figure out. I have a piece of text in a model, and I want it to flex in two directions when the family flexes. When I constrain it to the reference planes and adjust the size it asks me to remove a constraint. I'm failing to see why this is so hard for the family to understand. Please help me.
Attached you'll find two families. The test is the one is setup the way I would prefer, and the other is the only way I can think to keep it from breaking.
Jeff S.
File Type: rfa FH Base Cabinet-Flamm-Double Door-test.rfa (188.0 KB, 5 views)
jsteinhauer is offline   Reply With Quote
Old 2008-03-21, 07:41 PM   #2
Andre Carvalho
Andre Carvalho's Avatar
Andre Carvalho is glowing brightlyAndre Carvalho is glowing brightlyAndre Carvalho is glowing brightlyAndre Carvalho is glowing brightlyAndre Carvalho is glowing brightlyAndre Carvalho is glowing brightlyAndre Carvalho is glowing brightlyAndre Carvalho is glowing brightlyAndre Carvalho is glowing brightlyAndre Carvalho is glowing brightlyAndre Carvalho is glowing brightly
Default Re: Text doesn't like moving in to directions
Jeff,
I just downloaded the family "test" that you would prefer to use, unlocked the model text from the reference planes you had it locked to and added two dimensions to it: One vertical, from the bottom reference plane, to the center of the model text and to the top reference plane and EQ'd the dimension. Then added another one, horizontal, from the center reference plane to the center of the model text and to the edge reference plane. Then EQ'd it too.
If you open my file you can clearly see what I've done.
Andre Carvalho
File Type: rfa Base Cabinet-Flamm-Double Door - Andre.rfa (188.0 KB, 9 views)
Andre Carvalho is offline   Reply With Quote
Old 2008-03-25, 11:52 PM   #3
jsteinhauer
Originally Posted by Andre Carvalho View Post
Jeff,
Andre Carvalho
Andre,
Thank you for the quick response. Your fix works for the change in width, but not height. This is the same bump in the road I was tripping over. Does this mean I need different families for the different heights, just to get the text to display properly?
Please let me know if I'm missing somthing.
Sounds to me like a Wish List item. Flex text in two directions.
Jeff S.
Old 2008-03-26, 05:31 AM   #4
Andre Carvalho
Default Re: Text doesn't like moving in two directions
Jeff,
To make the model text move in both directions, I created it as a generic model (model text) and nested it into the cabinet family, locking it to the reference planes.
However, the problem I notice now (and I haven't enough time to take a better look at it at this moment), is that the nested model text just shows in isometric view... Anyway, the family is flexing (you can check it in sometric view) and if you can''t figure out the model text elevation visibility issue, as soon as i have a spare time I can try to help you with that too.
Regards,
Andre Carvalho
Old 2008-03-26, 09:32 AM   #5
Steve_Stafford
Revit Forum Manager
Steve_Stafford's Avatar
Steve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellation
It appears that a face based family doesn't want to display model text in the elevation view when nested. A generic model that is work-plane based however does. I've attached the cabinet with my family off to the side of the previous signage. You can edit that family and see what I did...nothing major. I did add a parameter to control the text height and the signage text. Hope it helps...
Steve_Stafford is offline   Reply With Quote
Old 2008-03-26, 03:16 PM   #6
Andre Carvalho
Thanks Steve. Should we consider it as a bug or just a software limitation?
Regards,
Andre Carvalho
Old 2008-03-27, 03:35 PM   #7
jsteinhauer
Smile Re: Text doesn't like moving in two directions
Regards,
Andre Carvalho
Steve & Andre,
Thank you so much for helping me with this. I agree with Andre this should be considered as a bug in the software. Now I need to fix my families before and update me project model before 9 tomorrow morning. As well as the other redlines I need to pick up.
Thanks again you two. This was seriously disturbing me.
Jeff S.
p.s. I took Steve's example to the next level thinking I was safe. But I got burned in legend view. I nested several Signage types into the family, and controlled them with a yes/no. In legend view, I'm unable to modify the visibility settings. I'm thinking of using a family type instead of yes/no. But, I'm unsure if this will work either. Hopefully this makes sense to someone.
Last edited by jsteinhauer : 2008-03-27 at 07:17 PM. Reason: Added post script message
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
moving dimension text johnd AutoCAD General 2 2007-04-27 04:00 PM
Independently moving label text for stairs Chad Smith Revit Architecture "Original" Wish List (Archived) 7 2006-07-19 10:31 PM
dtext - moving cursor to new text line paul.103763 AutoCAD General 1 2006-01-22 12:01 AM
Moving Text with Wipeout lem AutoCAD General 3 2005-03-07 01:40 AM
Dimension - moving text tonyisenhoff Revit Architecture - General 1 2004-11-06 12:23 AM
