Tuesday, February 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > Civil Engineering > AutoCAD Civil 3D Support > AutoCAD Civil 3D - Wish Lists > AutoCAD Civil 3D Wish List (Archive) > CIVIL3D-003 (Archived)
 Welcome, Guest.
Login
Thread Tools Display Modes
Old 2008-05-01, 08:52 PM   #1
Civil 3D Wishes
Wish List Administration
Civil 3D Wishes appears to be going the right way
Default Parts Builder Wizard
Summary: 1.) I wish I could add connection points and or penitrations to structures created in parts builder on the fly. These connection points and or Penitrations should have the ability to be added on the fly and relocated if need be. This allows connections at the wall and elevation, giving the ability of true inside drop structure design and pump station design.
2.) Also the ability to rotate the cone section of the model part upon insertion or after the fact when field varified witout changing connection point locations.
Description: 1.) I wish I could add connection points and or penitrations to structures created in parts builder on the fly. These connection points and or Penitrations should have the ability to be added on the fly and relocated if need be. This allows connections at the wall and elevation, giving the ability of true inside drop structure design and pump station design.
How Used: 1.) This will allow me to add new systems to old deisgns under expansion projects. Also it will cut down on custom configured manholes, chambers, pump station vaults etc...
This will allow me to make the pipe connection at wall of structure rather than center of structure. This will help on not needing to create multi-configurations of manholes. Worst case: A 4 pipe run with 4 drop structures in one manhole.
2.) The location of a lid is important under design so as not to position the manhole lid in the area of the road where it will get the most abuse.
Feature Affinity: Pipes
Submitted By: Allen Closson on March 5, 2008
Civil 3D Wishes is offline
Old 2008-07-17, 04:29 PM   #2
AutoCAD-AL
AutoCAD-AL is starting their journey
Thumbs up Re: Parts Builder Wizard
Great idea. This will help increse productivity by not having to create multiple structures because of differant connection points.
AutoCAD-AL is offline
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Parts From the CC Display Modified Lengths in Parts List Inventor Wishes INV-005 (Archived) 0 2007-09-25 02:42 AM
Parts Builder - too much information avn AutoCAD Civil 3D - Pipes 1 2007-05-08 11:19 PM
Parts Builder avn AutoCAD Civil 3D - Pipes 2 2007-03-21 06:10 PM
Mirror Assembly Parts as True Parts Inventor Wishes INV-002 (Archived) 0 2006-07-09 06:03 AM
e-builder? cparvez CAD Management - General 0 2004-11-29 02:56 PM
