Hi pipedream,
I'll try to head you in the right direction and let you tweak it to look the way that you want. I don't work with piping so I'm not sure if there is an Out-of-the-box (OOTB) property set (PSD) that has the properties you need so I'll create a new one.
- Go to FORMAT - Style Manager - Documentation Objects - Property Set Definitions.
- Right Click on Property Set Definitions and select New
- Name the PSD "PipeFittingObjects"
- Click the "Applies To" tab and Click "Objects" for Applies to and Click "Pipe Fitting" and "Pipe Custom Fitting".
- Click on the Definition tab.
- Click on the "Add Automatic Property Set" button (Looks like a lightning bolt)
- Click on :Connection Diameter" and click OK
- Repeat step 5 and add "Path Angle"
- Now click on FORMAT - Style Manager - Documentation Objects - Schedule Table Styles. Right click and select New
- Name this "Pipe Fitting Schedule"
- Click on the new schedule you just created and click on the "Applies To" tab.
- Select "Pipe Custom Fitting" and "Pipe Fitting"
- Click on the Columns Tab and then click Add Column
- Add the Connection Diameter
- Repeat step 13 and add Path Angle
- Click the "Include Quantity Column" check box near the bottom of the dialog.
You can now add this schedule to your drawing. You will probably get all question marks in the cells. Just right click the schedule and pick Add all Property Sets.
The Pipe length schedule is similar to this.
Please note AMEP schedules will not subtotal items so you'll need to export the conduit schedule to Excel to subtotal the pipe lengths by size.
Also, I have given you just the basic steps. You can do so much more with how you want the schedule to look and how you want the data to look. Play with what I've given you so far and don't hesitate to post back with any questions.
