Welcome, Guest.
Thread Tools | Display Modes |
#1 |
Wish List Administration
Summary: I wish walls and floor materials were part of the room properties and from this generated a finish schedule.
Description: I wish walls and floor materials were part of the room properties and from this generated a finish schedule. How Used: I would add 3-d materials (e.g. carpet, wall tile pattern) to the Room properies and the material pattern would appear on elevations and on a finish schedule. Interior finishes such as paint would then be part of the integrated model. Feature Affinity: Schedule tables Submitted By: Nicole Peterson on March 4, 2008 |
#2 | |
__________________
Greg Gebert Dell Precision T3400 Windows XP x64 Intel Core 2 Quad CPU Q6600 @ 2.4GHz 8GB Ram NVIDIA Quadro FX1700 (512MB) |
#3 |
I think the associativity would have to be the other way round. It's possible to have many different materials facing into a room and applying them automagically could really break things. Better to scan the room boundaries and pick up the material definitions from the bounding objects.
#4 | |
__________________
#5 | |
"I would add 3-d materials to the Room properies and the material pattern would appear on elevations" This implies that the Room object will modify the Wall objects. It has to be the other way round. |
#6 | |
Gordon |
#7 |
Exactly my point. The wish, as described, is too simple. Implementing it properly, without Revit making a bunch of assumptions, would be very tricky indeed.
#8 |
Agreeing with Gordon and Tom. The ability to add Shared Parameters is a very flexible way to customize an element to address what is relevant to that project (for purposes of scheduling). There will always be vast variation on how and when finishes are applied - just between projects, let alone across the profession! - that a prescriptive tool would likely always fall short.
We've tasted the honey of bidirectional associativity, and while I would love to see it function across all model data, the specificity of finish application is one aspect that I believe could be hindered by too much automation. THAT SAID, if Split Faces applied to a wall automatically created a room parameter that you could assign a palette material to.... hmmmmmm..... [tapping fingers in Montgomery Burns fashion)
__________________
Nancy McClure, Assoc AIA, LEED AP AEC Application Specialist Ideate Inc. "The best time to plant a tree was 20 years ago. The second best time is now." - Chinese Proverb |
#9 |
I like this idea very much. It's currently very difficult to make finish schedules as FLOOR finish schedules do not allow you to refer to ROOM information... (somehow WALLS let you refer to ROOM information though)
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Make wall location properties more accessible | Revit Wishes | REVIT-ARCH002 (Archived) | 0 | 2008-01-31 10:20 PM |
| Room schedule with wall finish | Wagurto | Revit Architecture - General | 5 | 2008-01-17 02:52 AM |
| How to make a wall cut a floor? | patricks | Revit Architecture - General | 3 | 2008-01-02 01:51 PM |
| Floor/wall materials | sjsl | Revit Architecture "Original" Wish List (Archived) | 1 | 2004-11-30 10:41 AM |
| Make a finish extend beyond the logical top/bottom of a wall | Wes Macaulay | Revit Architecture - Tips & Tricks | 4 | 2004-04-26 07:53 PM |
