Welcome, Guest.
| AutoCAD Electrical - General Ask your AutoCAD Electrical questions here! |
Thread Tools | Display Modes |
#1 |
I have a problem trying to show a terminal on more than one page, for example the internal connection may be on a different sheet to the outgoing (field) connection. When I generate a table view it creates two terminals instead of one. This is for example a 0V connection in a bank of terminals with a terminal jumper.
Thanks in advance Colin |
#2 |
Are you using two terminal blocks or just showing one on the most likely sheet then using power flow’s (signal source and destination arrows) connecting to the next sheet?
__________________
AutoCAD Electrical 2010 (ATP Instructor) soon Autodesk Revit Architecture 2010 AU - 2008 |
#3 |
I am using two terminal block symbols to represent one terminal block, when I generate a table I get multiple connections shown.
#4 |
I have been working with this exact problem for one of our customers.
I have been playing with "Link Terminal Number" to text to try to create a dummy terminal or parent child relationship. I have not had the time to look into this as deeply as I would like. If someone has a better way I would love to hear it. Stan Wile
__________________
Stan Wile |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Terminal Server DWG Viewer | madcadder | Software | 6 | 2007-02-14 04:28 PM |
| Terminal Server Drawing Viewer | MMccomb | DWG TrueView - General | 1 | 2007-02-08 09:46 AM |
| Revit with Terminal Services | Mr Spot | Revit - In Practice | 23 | 2006-09-27 04:15 PM |
| Terminal Services | crogersak | Networks | 1 | 2004-10-23 03:50 AM |
