Tuesday, February 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > Inventor Support > Inventor - Wish Lists > Inventor Wish List (Archive) > INV-007 (Archived)
 Welcome, Guest.
Login
Thread Tools Display Modes
Old 2008-06-09, 04:29 PM   #1
Inventor Wishes
Wish List Administration
Inventor Wishes is going the right wayInventor Wishes is going the right wayInventor Wishes is going the right way
Default Variable Value Constraints
Summary: Be able to add variables to assembly constraints
Description: I would like add constraints with variable values. For example: a range between min en max value.
How Used: In the constraint dialogbox I would like to have the option to enter more than one parameter and choose the range between those two offset values (min and max value) of the constraint.
Feature Affinity: Assemblies
Submitted By: Nico De Neef on April 15, 2008
Inventor Wishes is offline
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Variable height/variable count family (studs in a sloped wall) DoTheBIM Revit Architecture - Families 6 2006-06-15 04:48 PM
Constraints lbloomfi Inventor - General 2 2005-09-21 09:51 PM
Constraints: Sightline Based Constraints ronjon Revit Architecture "Original" Wish List (Archived) 0 2005-01-11 03:40 PM
Regarding Constraints, I should probably know this by now, but.... WolffG Revit Architecture - General 3 2004-11-24 03:34 AM
