Tuesday, February 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > AEC > Revit > Revit Architecture Support > Revit Architecture - General
 Welcome, Guest.
Login
Revit Architecture - General Main discussion area for the latest release of Revit Architecture.
Reply
Thread Tools Display Modes
Old 2008-06-18, 10:40 AM   #1
Elrond
Elrond's Avatar
Elrond is a shining starElrond is a shining starElrond is a shining starElrond is a shining starElrond is a shining starElrond is a shining starElrond is a shining starElrond is a shining starElrond is a shining starElrond is a shining starElrond is a shining star
Default RAC2009 + IES VE-Ware
Has anyone installed and used the free VE-Ware from IES?
So far I get an "unrecoverable error" when I select the Set Model Properties button... Not sure if it is the file size or complexity or the software itself...
EDIT - having tried a very very simple model (2 rooms) it seems to work fine... and has a very nice clear output. It doesn't look very detailed but I haven't really played with it much.
(a bit frustrating that all the wall type etc are in imperial units for some reason... wonder who it is really aimed at...! )
__________________
Elrond Burrell, Architect
[Connect with me on LinkedIn or Twitter]
"The best time to plant a tree was 20 years ago. The second best time is now."
- Chinese Proverb
Elrond is offline   Reply With Quote
Old 2008-06-18, 11:04 AM   #2
vennix
vennix is going the right wayvennix is going the right way
Default Re: RAC2009 + IES VE-Ware
I installed it and it seems to work oke.
Too bad you cant set the units
Even worde the toolkits are no longer free.
I tried installing the toolkits but something went wrong.
Now I get an error when I try to uninstall the toolkit
Geert
vennix is offline   Reply With Quote
Old 2008-06-18, 11:07 AM   #3
Elrond
Elrond's Avatar
It seems to dump a load of files on the desktop also... which I can't see where you can set the default file save locations or anything...
__________________
- Chinese Proverb
Old 2008-06-18, 11:21 AM   #4
Elrond
Elrond's Avatar
I found a units setting - although it doesn't seem to change the material definitions from a mixture of imperial and metric...
It is under the menu IES <VE> --> about
__________________
- Chinese Proverb
Old 2008-06-18, 11:04 PM   #5
Elrond
Elrond's Avatar
I guess not then huh?
__________________
- Chinese Proverb
Old 2008-06-19, 12:43 AM   #6
dbaldacchino
Count (Formula)
dbaldacchino's Avatar
dbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining star
Just installed and am playing around with it. Will post findings later.
__________________
dbaldacchino is offline   Reply With Quote
Old 2008-06-19, 03:52 PM   #7
dbaldacchino
Count (Formula)
Ok I'm back
I tried running it on an Elementary School project and it crashes before I can even review the model or set settings. So I decided to build a simple model and test on that. It seems to work fine, although I managed to crash several times even on a small tiny model (about 6 exterior walls, some interior walls, 4 rooms and a shape-edited planar roof.
Going through the white paper is valuable to figure out some of the settings and make sure your analytical model is correct. Things such as turning on volume calculations for your project and raising your room upper limits and offsets so they intersect other room bounding elements such as ceilings and roofs. When you check the model, it will tell you if there are "holes" in the surfaces and you can isolate each room surface model to investigate. In most cases it seemed to mess up at changes of direction of the roof when walls had the top attached. So some model tweaking might be necessary. The analyitical model is made up of flat 2D planes and that's why it might have difficulty at times to resolve complex shapes.
One thing I'm a bit disappointed about is that you have to manually select the type of roof, walls etc. Isn't that why we're modeling in Revit? Why do I have to go tell it again what my assembly is? The program should be taking my roof element in Revit and figuring out what the R value is. Obviously right now Revit doesn't keep track of that information so it's understandable, but hopefully this gets resolved soon or it'll be too time consuming. Revit either needs to store that information or there should be some mapping feature to tell VE-Ware that this specific wall has this U value, etc.
My building didn't pass the 2030 challenge It would be nice to get some sort of feedback as to where the major hit was taken; what type of improvements could I do to get it to pass? Obviously it could be there and I missed it as I haven't combed through the resulting report. I'll continue testing today and see what else I can find out.
EDIT: Also, why am I forced to select a mechanical system? Why cannot I select "Natural Ventilation" for example?
__________________
Last edited by dbaldacchino : 2008-06-20 at 07:38 AM. Reason: Further observations
Old 2008-06-23, 06:13 PM   #8
padgham.graeme
padgham.graeme is infamous around these parts
I have installed and used the VE Toolkit, I have run it on a large airport with a very complicated curved roof system (lots of 'waves). I takes about 5 minutes to enter the VE Modeler but so far has never crashed.
it is well worth (as said above) downloading and reading all the PDF files on the website, this will help no end with modelling correctly for analysis with the VE toolkit, you really cant use it without following the strict guildlines.
__________________
Graeme Padgham
Head of 3D Solutions
padgham.graeme is offline   Reply With Quote
Old 2008-06-24, 01:39 AM   #9
dbaldacchino
Count (Formula)
Thanks for your feedback. I can't tell what's wrong with my test project, but I know I tried it on a model that's not perfectly complete, so some checking would be in order before I try it again.
Are we talking about the same plugin though? You're mentioning the "toolkit" and in RAC2009, those options all require a license. Anyway, for the VE-Ware part, I was very surprised not to find an option to run calculations on a building without using a mechanical system for heating and cooling. Unless I'm missing something, there's no option to do this. What if I want to see how a building performs in a certain location and climate just by naturally ventilating it? Why should I be forced to select a mechanical system? Anyone else find this peculiar?
__________________
Old 2008-06-24, 05:42 AM   #10
kyle.bernhardt
kyle.bernhardt's Avatar
kyle.bernhardt is a beam of lightkyle.bernhardt is a beam of lightkyle.bernhardt is a beam of lightkyle.bernhardt is a beam of lightkyle.bernhardt is a beam of lightkyle.bernhardt is a beam of lightkyle.bernhardt is a beam of lightkyle.bernhardt is a beam of lightkyle.bernhardt is a beam of lightkyle.bernhardt is a beam of lightkyle.bernhardt is a beam of light
All,
I know the folks at IES well as very capable developers, and certainly a brilliant bunch. It sounds like you folks have found some situations that aren't jiving well with their initial release of the VE-Ware capability.
I'll pull them into this thread to address some of the issues you've found, as well as some of the questions.
Cheers,
Kyle B
__________________
Product Manager
BIM Emerging Technologies & Simulation
Read the MEP blog
Smart Questions = Smart Answers
Twittering away
kyle.bernhardt is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
RPC not showing in RAC2009 andre.gawlik Revit - Rendering 2 2008-05-12 09:56 AM
fichiers d'installation RAC2009 pomalt13 Revit Architecture - Général 4 2008-04-22 05:59 PM
VM Ware vs Dedicated Servers sandra.corkern Facilities Management In Practice 1 2008-04-17 08:32 PM
RAC2009 samuelsonlarry Revit Architecture - General 152 2008-03-09 02:55 PM
