Tuesday, February 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > AEC > Revit > Revit Architecture Support > Revit Architecture - Wish Lists > Revit Architecture - Wish List (Archive) > REVIT-ARCH003 (Archived)
 Welcome, Guest.
Login
Thread Tools Display Modes
Old 2008-06-19, 05:46 PM   #1
Revit Wishes
Wish List Administration
Revit Wishes appears to be going the right way
Default More Stair options
Summary: More landing options and rail returns and clean ups.
Description: More Stair options, I would like to be able to select to have a landing at either the top, botton or both ends or the stair run along with allowing all rail returns and clean up. Also option to allow bottom rail to extended past run per min arch. standards. (balluster type?)
How Used: Need revit stairs to be more real world oriented, min standard rail to rail
Feature Affinity: Stairs, Ramps, and Railings
Submitted By: Andrew Brown on March 17, 2008
Revit Wishes is offline
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Stair Issues (was Stair Improvements) david.kingham Revit Architecture - General 4 2005-10-27 12:26 AM
How can I create a split T-stair without multiple and or separate stair components? cosmickingpin Revit Architecture - General 2 2005-01-20 06:16 PM
Can I make this stair with the stair object? Nic M. Revit Architecture - General 7 2004-04-28 02:13 PM
Stair Study - Design Options example discussion (moved here) andrewg Revit Architecture - General 16 2004-01-27 02:02 PM
Stair cut line display in 3 riser stair 4christo4 Revit Architecture - General 1 2003-09-01 10:53 PM
