Tuesday, February 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > AEC > Revit > Revit Architecture Support > Revit Architecture - Wish Lists > Revit Architecture - Wish List (Archive) > REVIT-ARCH003 (Archived)
 Welcome, Guest.
Login
Thread Tools Display Modes
Old 2008-06-28, 05:29 PM   #1
Revit Wishes
Wish List Administration
Revit Wishes appears to be going the right way
Default Reference Label "Sym" as an Instance Parameter
Summary: For the Reference label ("Sym.", "Typ.", "Opp. Hand") to be returned to an instance parameter rather than a type parameter.
Description: For the Reference label ("Sym.", "Typ.", "Opp. Hand") to be returned to an instance parameter rather than a type parameter.
How Used: This has been broken since around release 6. In the current for the feature is unusable. As an instance parameter, different reference text can be insterted to properly identify the correct reference situation.
Feature Affinity: Annotation tools
Submitted By: Aaron Rumple on May 14, 2008
Revit Wishes is offline
Old 2008-07-01, 05:45 PM   #2
Scott Hopkins
Scott Hopkins's Avatar
Scott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moonScott Hopkins is reaching for the moon
Default Re: Reference Label "Sym" as an Instance Parameter
Agreed. I'd always wondered if I had been using this incorrectly. It has been broken for way too long.
__________________
Revit 2010 - Autodesk commences "Operation Destroy Revit"
Scott Hopkins is offline
Old 2008-07-01, 07:09 PM   #3
patricks
Certified AUGI Addict
patricks's Avatar
patricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moonpatricks has landed on the moon
I don't remember this ever being an instance parameter. I remember being able to create different types of sections with Sim or Opp, etc. back in version 6 and 7, and then around 7.1 or 8, this was no longer possible.
However this was actually fixed in 2008. We can now once again create different section and detail types with Sim, Opp or whatever else we need.
__________________
Intern Architect
AERC, PLLC
Hernando, Mississippi
patricks is online now
Old 2008-07-01, 07:10 PM   #4
patricks
patricks's Avatar
But yeah it would be nice to have it as an instance parameter.
__________________
Intern Architect
AERC, PLLC
Old 2008-07-01, 11:58 PM   #5
aaronrumple
Revit Mararishi
aaronrumple's Avatar
aaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining staraaronrumple is a shining star
Originally Posted by patricks View Post
...version 6 and 7, and then around 7.1 or 8, this was no longer possible.
As I recall, it was broke after version 6.5.
__________________
We're sorry - the factory has closed.
Aaron Rumple, AIA
aaronrumple is offline
Old 2008-07-21, 04:19 PM   #6
pleasantc
pleasantc is infamous around these parts
Really? I haven't been able to actually use the other tag types I've created for the purposes of using "SIM." If you reference another view, the tag automatically switches to the same type as the view you're referencing. I think it would be handy if it could be set up to automatically put SIM by the tag if you have selected "reference another view."
pleasantc is offline
Old 2008-07-29, 07:49 PM   #7
jhalaby
jhalaby is starting their journey
Agreed - "Sim, Typ, Opp" is much more useful as an instance parameter. Until this is fixed, we will be using text notes instead.
__________________
Jason Halaby
__________________
DeStefano + Partners
jhalaby is offline
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Selecting a list of folders and removing all ".bak", ".err", ".xlg" & "plot.log" files from folders & sub folders stephen.coff AutoLISP 5 2009-04-17 12:10 PM
Label, Instance Parameter and Title blocks Gordon.Price Revit Architecture - Families 3 2007-08-03 08:36 PM
Add Pipe Label "Label Type" default luke.104954 AutoCAD Civil 3D - "Original" Wish List (Archived) 0 2006-02-16 01:14 AM
Can't get stretchable instance parameters to "snap"... iru69 Revit Architecture - Families 6 2005-10-20 10:53 AM
blank label prints "?" ctc Revit Architecture - Families 3 2004-12-01 02:49 AM
