Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2008-07-11, 09:10 PM   #1
kbiv
kbiv is infamous around these parts
Default Automatic wire numbers
ACADe2k7 will not auto number wires connected to certain components that I've created using symbol builder. If I cut them so they're not connected it will do it but if they're attached it won't.
kbiv is offline   Reply With Quote
Old 2008-07-23, 06:30 PM   #2
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
Default Re: Automatic wire numbers
what does your components consist of? Do you have terminal points? X4TERM01? It might even be your wire layers not your component. Is the line on a wire layer? What does the history read; AutoCAD Text Window (F2) after you try to automate the wire number? Oh, is the wire number there and just not updating? Maybe a picture would help.
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Old 2008-08-18, 08:24 PM   #3
gsanchez23
Manufacturing Moderator
gsanchez23's Avatar
gsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightly
Kbiv, let me know if you solved your issue, if not, I would like a .dwg.
__________________
George Sanchez
Technical Expert, MICE, DMICE, ICE
U.S. CAD
San Diego, CA.
gsanchez23 is offline   Reply With Quote
Old 2008-11-11, 06:19 PM   #4
kbiv
Yes, problem solved. Thanks everyone!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Make CSV File Work Like XML Updating Wire Numbers Inventor Wishes INV-007 (Archived) 0 2008-06-09 04:06 AM
Ability to have letters as well as numbers in as revision sequence numbers Revit Wishes REVIT-ARCH001 (Archived) 1 2007-10-01 03:07 PM
Translate nVidia installer numbers to driver numbers Andre Baros Revit - Hardware & Operating Systems 4 2007-02-14 06:08 PM
Wire Numbers for component and terminal RenataP AutoCAD Electrical - General 0 2006-10-31 07:06 PM
linked room numbers & door numbers tim.101799 Revit Architecture "Original" Wish List (Archived) 5 2006-07-18 10:44 PM
