Is it possible to insert a pdf file into AutoCAD to use as a background, such as you could use a tif file as background for a drawing?
Hi
Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
ID: TS43623 - Importing PDF files
<add>
Oops, should have directed you in the first place to the following thread -
Importing PDF files
</add>
Have a good one, Mike
If you have Adobe Acrobat full version, you can save the PDF files as PNG file with a transparent colour (colour 255).
You can then use image manager in AutoCAD to attach the image, and set transparency to ON. This will produce the result you desire.
Scott
Here are some applications that can assist in converting (or importing) a PDF into a DWG or DXF.
R.K. McSwain | CAD Panacea |
