Tuesday, February 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > AEC > Revit > Revit Architecture Support > Revit Architecture - General
 Welcome, Guest.
Login
Revit Architecture - General Main discussion area for the latest release of Revit Architecture.
Reply
Thread Tools Display Modes
Old 2008-08-15, 03:44 PM   #1
MRV
MRV has a bright futureMRV has a bright futureMRV has a bright futureMRV has a bright futureMRV has a bright futureMRV has a bright future
Angry Property lines changed in dwg imports!
I just imported a survey dwg file into my project, and two of the four property lines in the import were changed, from a bearing of N89 57 56W to N90W !!! These were not native Revit lines, but the property lines in the dwg file! This is a huge issue for us, for now we can't rely on the surveyor's dwg files to import into Revit!
Originally Posted by Autodesk Support
Unfortunately this is a limitation with Revit - if the program encounters a line that is almost horizontal, it will make it exactly horizontal. Unfortunately there is no way to modify the precision of imported lines. Development is aware of this issue and they are looking at ways to improve this functionality in future releases. The only workaround, at this point, is to break the line up into smaller segments. Revit will still adjust the lines, but the changes will be less noticeable.
I've always believed that I could trust the import dwg files to be correct, but now I found out that Revit is changing the entity coordinates, and you have no way to know what is changed!!!
__________________
Michael Vaughn
BWG Architecture
Last edited by Steve_Stafford : 2008-09-20 at 09:03 PM. Reason: removed font formatting codes and added quote codes
MRV is offline   Reply With Quote
Old 2008-08-15, 05:41 PM   #2
tomnewsom
tomnewsom's Avatar
tomnewsom is glowing brightlytomnewsom is glowing brightlytomnewsom is glowing brightlytomnewsom is glowing brightlytomnewsom is glowing brightlytomnewsom is glowing brightlytomnewsom is glowing brightlytomnewsom is glowing brightly
Default Re: Property lines changed in dwg imports!
O_O !!!!
This is unforgiveable behaviour! Fix it now now now please, autodesk.
tomnewsom is offline   Reply With Quote
Old 2008-08-16, 12:13 AM   #3
echo
echo is going the right wayecho is going the right wayecho is going the right wayecho is going the right wayecho is going the right way
Originally Posted by MRV Quoting Autodesk
...Unfortunately this is a limitation with Revit - if the program encounters a line that is almost horizontal, it will make it exactly horizontal...
This goes hand in hand with warnings that your "line is slightly off-axis and may cause inaccuracies." Same behvior trend. I have heard of the same issue with arcs created by a trigonometric formula in a family parameter on a very large job...
-LC
echo is offline   Reply With Quote
Old 2008-08-18, 02:15 PM   #4
Liz437
Liz437's Avatar
Liz437 is infamous around these parts
Absolutely unforgiveable!! We have a very large slightly curved building, and generate over 2000 (yes, that’s OVER 2000!!) warnings in each model of ‘line is slightly off axis’ which we can’t get rid of & simply bloat our model. Everyone does not build or design at 90*. This is, for us, a serious problem and deserves some correction. There is no reason that a line ‘slightly off’ vertical or horizontal should generate a problem.
Liz437 is offline   Reply With Quote
Old 2008-08-18, 10:58 PM   #5
echo
Over 2000 just for "line is slightly off axis???" How many lines are being corrected, then, if there are that many warnings? Do you see similar things to what MRV originally posted that the lines were auto-correcting to due horizontal?
Old 2008-08-18, 11:28 PM   #6
Liz437
Liz437's Avatar
Yep, we have an average of around 2000 warnings per project file just of ‘line slightly off axis.’ With 13 project files linking into one another to create the one model you can see where our performance suffers. Nothing we can do about "slightly off axis" other than delete, which, obviously, is not an option, as that would delete essentially our entire project.
The 'break into smaller segments' makes zero sense in our case, as lines would continue to be 'slightly off axis.' We have seen some auto-correct, but really have a very hard time keeping track of those occurrences.
Old 2008-09-20, 12:53 AM   #7
Liz437
Liz437's Avatar
This is STILL a hot-button issue with us; serious problem.....anyone?
Old 2008-09-20, 09:50 PM   #8
Steve_Stafford
Revit Forum Manager
Steve_Stafford's Avatar
Steve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellationSteve_Stafford has become a constellation
This doesn't resolve or change how Revit deals with the imported lines in the cad file. If you enter the property boundary data into the Table of Distances and Bearing you'll find that Revit is willing to display this information accurately.
Are the 2k lines that are generating the errors Revit lines? I find that if you put details that have such errors in a detail component family first and place that in the project that the errors do not follow the family into the project. I don't know if this is practical for your situation or not. In my case we had many many cad details that were getting imported and exploded into a project (bad idea). This generated many such warning as you can imagine. We removed this work and did the "same" thing in a detail component family and placed this family instead, no errors in the project.
Steve_Stafford is offline   Reply With Quote
Old 2008-09-22, 09:07 PM   #9
sbrown
Early Adopter
sbrown's Avatar
sbrown is shooting for the starssbrown is shooting for the starssbrown is shooting for the starssbrown is shooting for the starssbrown is shooting for the starssbrown is shooting for the starssbrown is shooting for the starssbrown is shooting for the starssbrown is shooting for the starssbrown is shooting for the starssbrown is shooting for the stars
I'm running into this type of error on a remodel. The as-built revit model is just that as-built, so walls aren't truely square and its a bit of a pain. I'm hoping the performance isn't affected by the warnings. The property line issue is huge though. Have you filed a support request and if so what did they say. Thats definately NOT something they can leave unfixed for long.
__________________
Scott D. Brown, AIA
Project Coordinator | Director of Building Information Modeling
HHCP.com
sbrown is offline   Reply With Quote
Old 2008-09-22, 11:15 PM   #10
MRV
They basically told me that's the way it is, take it or leave it. I was pretty upset about the whole thing at the time, and haven't calmed down a whole lot since then. I was drawing whole subdivisions by sketching over the dwg file, and never noticed the property lines were being changed. That's the really bad part, Revit was changing the lines without any notification at all. My trust factor in Revit drawings is down a few notches now, I don't assume anything is correct now without verifying!
__________________
Michael Vaughn
BWG Architecture
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Fill Patterns from DWG imports annl Revit Architecture - General 2 2007-10-15 06:18 PM
Autocad Imports - inconsistent lines PaperStreet SoapCO Revit Architecture - General 7 2007-05-09 09:15 PM
dwg imports V9ok V9.1 ? orava Revit Architecture - General 4 2006-10-05 11:05 PM
Elevations with 3d dwg imports? juggergnat Revit Architecture - General 1 2005-09-12 05:51 PM
Query dwg imports Martin P Revit Architecture - General 2 2005-01-13 02:06 PM
