Thursday, July 29, 2010
Go Back   AUGI Forums > AUGI Technical (English) > General Design > AutoCAD > AutoCAD Community > AutoCAD Tips & Tricks
 Welcome, Guest.
Login
AutoCAD Tips & Tricks Tips from the experts and tricks from the trenches. Post ONLY tips or tricks. This is NOT a Q&A forum for AutoCAD.
Reply
Thread Tools Display Modes
Old 2008-09-12, 05:09 AM   #1
balubharadwaj
balubharadwaj appears to be going the right way
Smile Locate the Mid point between 2 points Using MTP Snap method
Locates the midpoint between two points
Command entry: At a prompt to locate a point, enter mtp
The midpoint between two points (MTP) command modifier can be used with running object snaps or object snap overrides. (OSNAP command)
At any Command prompt to locate a point, enter mtp or m2p.
First point of mid: Specify a point
Second point of mid: Specify a second point
Example
If we want to draw line between mid of two rectangles
Start a line command and type MTP Program will ask for two points
Select the two opposite corners of rectangle.
Repeat the same procedure for the other point
balubharadwaj is offline   Reply With Quote
Old 2008-09-12, 11:18 PM   #2
Gigliano70
Gigliano70's Avatar
Gigliano70 is glowing brightlyGigliano70 is glowing brightlyGigliano70 is glowing brightlyGigliano70 is glowing brightlyGigliano70 is glowing brightlyGigliano70 is glowing brightlyGigliano70 is glowing brightlyGigliano70 is glowing brightlyGigliano70 is glowing brightly
Default Re: Locate the Mid point between 2 points Using MTP Snap method
In 2007 you can set your F1 key to be a shortcut key instead of help which can suck immensely. I have mine set to M2P.
__________________
Frank R. Giaquinto
I am logged in - Therfore, I am.
Blessed are they who can laugh at themselves, for they shall never cease to be amused."
Gigliano70 is offline   Reply With Quote
Old 2008-10-19, 08:34 PM   #3
d.vulic
d.vulic is infamous around these parts
Start a line command and instead of typing MTP or m2p
you press CTRL + mouse right click button
and select from screen “Mid Between 2 Points”
select the two opposite corners of rectangle and
than repeat the same for opposite object.
For me easier and faster then typing MTP or m2p
d.vulic is offline   Reply With Quote
Old 2009-09-01, 12:43 PM   #4
Sureshrrai
Sureshrrai is going the right waySureshrrai is going the right way
Thumbs up Re: Locate the Mid point between 2 points Using MTP Snap method
verry nice tip
__________________
SURESH RAI
Sureshrrai is offline   Reply With Quote
Old 2009-09-04, 12:11 AM   #5
alimhmd4
alimhmd4 appears to be implodingalimhmd4 appears to be imploding
that is right
i already use FI as m2p
alimhmd4 is offline   Reply With Quote
Old 2009-09-04, 05:28 PM   #6
dzatto
Certifiable AUGI Addict
dzatto's Avatar
dzatto has become a constellationdzatto has become a constellationdzatto has become a constellationdzatto has become a constellationdzatto has become a constellationdzatto has become a constellationdzatto has become a constellationdzatto has become a constellationdzatto has become a constellationdzatto has become a constellationdzatto has become a constellation
Even faster is CTRL + right click to get your Osnap menu, then hit W. That's how I run all my snaps. Hit E for endpoint, M for mid point, C for center, etc, etc. I HATE running object snap on continuously.
__________________
Why is it called common sense when it is so rare?
Revit's starting to click people!!
Now if I could only grasp parametric families.....
Check out CADKicks.com
And while you're at it, check out bim-managers.com
dzatto is offline   Reply With Quote
Old 2009-09-22, 07:50 PM   #7
murrayc.49304
murrayc.49304's Avatar
murrayc.49304 is glowing brightlymurrayc.49304 is glowing brightlymurrayc.49304 is glowing brightlymurrayc.49304 is glowing brightlymurrayc.49304 is glowing brightlymurrayc.49304 is glowing brightlymurrayc.49304 is glowing brightlymurrayc.49304 is glowing brightlymurrayc.49304 is glowing brightly
I customize my Function keys to act as my object snap overrides. I have left F1 and F2 alone, and since the default Function key settings (Polar, Ortho, etc) are displayed at the bottom of your screen anyway, why not take advantage of customizing your Function keys?
__________________
"To associate your Dimensions is DIVINE.... To explode them makes you a TWIT!"
AutoCAD Guru
murrayc.49304 is offline   Reply With Quote
Old 2009-11-11, 01:59 PM   #8
drc6726
drc6726 is infamous around these parts
Could someone walk me through how to customize my f keys like mentioned here.
I use mtp or m2p all the time I love it. However I have always hated having to type it out like that. Would like to be able to hit one key and go. I agree that help being f1 is a pain.
I have mep 2009. I have a lot of cusom hot keys that I have created using the xpress tool alias editor. But I cannot seem fo find mtp in there. not the ability to edit the function keys.
Any help would be great.
Thanks.
drc6726 is offline   Reply With Quote
Old 2009-11-16, 10:29 PM   #9
RobertB
Administrator
RobertB's Avatar
RobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the starsRobertB has reached the stars
You need to use the CUI editor to assign commands to function keys. There is even a sample F1 CUI file located here.
__________________
R. Robert Bell
Design Technology Manager
S P A R L I N G
Opinions expressed are mine alone and do not reflect the views of Sparling.
RobertB is offline   Reply With Quote
Old 2010-01-19, 05:32 PM   #10
taliesyn.102216
taliesyn.102216 is starting their journey
Does anyone know what happened to the W? We've just finally gotten into 2009 and 2010, and suddenly it doesn't work anymore. Is there any way to reassign it?
__________________
Scott A.
Designer
TMAD Taylor & Gaines
San Diego
taliesyn.102216 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Mid Point betn two points mahesh.darekar AutoLISP 5 2008-05-05 01:48 AM
Placing insertion point at mid-point of flange on a steel section Spenner Dynamic Blocks - Technical 4 2007-06-18 02:53 PM
Mid between two points rjcrowther Revit Architecture - General 4 2007-04-25 06:51 PM
Locate Endpoints that do not connect, then indicate those points ricodominguez AutoLISP 18 2005-02-14 11:26 PM
Need Help with Mid 2 Point rklee AutoCAD General 8 2004-06-10 08:04 PM
