Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2008-09-24, 03:22 PM   #1
grendon
grendon is starting their journey
Question 3 Phase horizontal bus
Hi all! I'm starting with ACADe 2009. Could someone tell me how to insert a horizontal 3 phase bus on this version? on ACADe 2004 there was an option in the 3 phase bus tool, I can't find it now. Should I insert the wires one by one? Thanks!
grendon is offline   Reply With Quote
Old 2008-09-24, 04:40 PM   #2
grendon
Default Re: 3 Phase horizontal bus
Already figured out!! thanks anyway.
Old 2008-09-24, 06:47 PM   #3
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
Cool that you found it!
For any new ones who read this; This might help:
Under Wires pulldown, select Multiple Wire Bus which will bring up the dialog box.
Inside the box change spacing, select Empty Space, Go Horizontal (or Vertical) and the default is 3 for Number of Wires.
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Old 2008-09-24, 07:55 PM   #4
grendon
Smile Re: 3 Phase horizontal bus
Thanks for your help RenataP!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Combien de jambes/pattes sont dans le bus? Benoit D Français - Récréation 8 2007-12-11 09:17 AM
Control of Underlay Phase and Phase Filter? dbaldacchino Revit Architecture - General 2 2006-12-19 03:04 AM
Room Objects staying from phase to phase srobbins Revit Architecture - Tips & Tricks 0 2006-12-09 01:09 AM
