Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2008-09-24, 04:52 PM   #1
grendon
grendon is starting their journey
Red face Custom made components
I created a symbol for a transformer (didn't find it on the JIC Symbols list) on one drawing, and now need to know how to import it into a different drawing and different project. Can I create some sort of universal library with all the created devices? I'm using ACADe 2009.
Thanks!!
grendon is offline   Reply With Quote
Old 2008-09-24, 06:38 PM   #2
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
Default Re: Custom made components
Thanks!!
I am currently using 2008. Yet I think the process is the same.
We keep all our custom components in a folder inside the default folder for components on our server: P:\CONTROLS LIBRARY\2008\Libs\iec2\CMC & P:\CONTROLS LIBRARY\ACADE Libs\BIGjic125\CARDINAL. I have not transferred all the existing from 2007 to 2008 folder yet.
Then they are in one central location. I even have a menu created on the Insert Component dialog box.
Are you taking the Electrical classes from ATP (AUGI Training Program)? They are free and the teacher, George is doing a great job!
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Old 2008-09-24, 08:29 PM   #3
grendon
Smile Re: Custom made components
Thanks again Madam!! I'll try this and let you know how it goes. (I still need to get used to some of the elementary procedures in AutoCAD Electrical)
Old 2008-10-16, 07:02 PM   #4
gsanchez23
Manufacturing Moderator
gsanchez23's Avatar
gsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightlygsanchez23 is glowing brightly
Cool Re: Custom made components
Renata, thanks on the class props.
Grendon, did you add the block to the Icon menu? then as long as you are using the same library and icon menu the new component will be available.
George,
__________________
George Sanchez
Technical Expert, MICE, DMICE, ICE
U.S. CAD
San Diego, CA.
gsanchez23 is offline   Reply With Quote
Old 2008-11-05, 04:42 PM   #5
r424andy
r424andy's Avatar
r424andy has a bright futurer424andy has a bright futurer424andy has a bright futurer424andy has a bright futurer424andy has a bright futurer424andy has a bright future
[quote=RenataP;891064]I am currently using 2008. Yet I think the process is the same.
[quote]
I am glad you brought this up!! I am starting to adjust the exsiting default blocks for our use. My concept is to create a Custom shared folder for these blocks. This way when we update electrical we can still use the default blocks with our custom/modified blocks. My question is when i create/modify these blocks and save them to the new location (name remains the same) is there anything i need to change in the program to look for these files? one options is to add that new directory BEFORE the default files or do i have to change/modify the database files?
__________________
my launchcast station
Currently Useing 2009 AutoCAD Electrical
r424andy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
DWG true view - using in Custom made VB 6 applications ajman.a VBA 3 2008-05-24 04:08 PM
Custom Toolbars? Detail Components list unmanageable? Need advice... scowsert Revit Architecture - General 3 2007-09-17 07:15 PM
How to save custom components. boofredlay Revit Architecture - General 1 2006-05-10 09:06 AM
How to Load Custom Made Family in Project artitech Revit Architecture - Families 7 2005-06-25 05:17 PM
