Welcome, Guest.
| AutoCAD Electrical - General Ask your AutoCAD Electrical questions here! |
Thread Tools | Display Modes |
#1 |
I am trying to use a custom title block but the Title Block Setup cannot find the attributes I have defined. Am I missing a step? I have my block in Block Editor and have defined the attributes and have everything saved under that block definition.
#2 |
I'll see what the help menu says for 2009. I have 2008 and will put together a small demo of how I generate a <project>.wdt file.
__________________
AutoCAD Electrical 2010 (ATP Instructor) soon Autodesk Revit Architecture 2010 AU - 2008 |
#3 |
Manufacturing Moderator
can you provide me the block, I can check and see what is going on. As far as I have experienced 2008 and 2009 are the same for this area. Just make sure you have ab attrbuted block and the tool will find all attibutes.
__________________
George Sanchez Technical Expert, MICE, DMICE, ICE U.S. CAD San Diego, CA. |
#4 | |
Thanks Ken New to ACE |
#5 |
my experience with making a custom title block is that you have to remove the WD_TB that the program normally puts in for you, or it will not update properly. I scratched my head on this one for awhile. Hope this helps
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Adding Custom Labels to a Title Block | cadclips | Revit Architecture - Tips & Tricks | 0 | 2008-10-06 02:19 PM |
| Custom Title Block field.... view name | still.james | Revit Architecture - General | 1 | 2008-07-16 06:44 PM |
| Plot to DWF causes mystery lines to appear and removes a Block from title block | crystalp | AutoCAD Plotting | 1 | 2007-01-07 11:08 AM |
| Convert MDT Title Block to Inventor 10 Title Block | julesgordon | Inventor - General | 1 | 2005-07-18 10:34 PM |
| Plot a Custom Title Block from Sheet Set Manager | luke.siebert | AutoCAD Plotting | 3 | 2005-02-23 02:56 PM |
