Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2008-10-07, 03:18 PM   #1
david.brissenden
david.brissenden is infamous around these parts
Default Source Destination Question
Hello all,
When you have multiple destination signals linked to a source signal, the source signal shows all of the xrefs of the destinations - how do you prevent this? Hopefully the attached picture shows what I mean.
Another question; how do you stop the wire number appearing on the wire? If you have a short wire with a source or destination signal (as in the attached picture) you find that the wire is a bit crowded. It is essentially extra information that is of no use.
Thanks for any help.
david.brissenden is offline   Reply With Quote
Old 2008-10-07, 06:55 PM   #2
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
Default Re: Source Destination Question
Quick answer; modify the block by making the attribute invisible.
I’ll try and review the attachment tonight.
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Old 2008-10-08, 08:44 AM   #3
david.brissenden
That seems much simpler and automated.
Thanks for your help
Old 2008-10-08, 06:37 PM   #4
RenataP
RenataP's Avatar
Flip Attributes to Invisible: using Components menu --> Attributes > Hide/Unhide Attributes > Hide Attributes (Window/Multiple)
See doc. attached
happy to help!
__________________
AU - 2008
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
New Source for Families bclarch Revit Architecture - Families 2 2008-05-29 01:22 PM
Source Drawing smooth shoes AutoCAD General 8 2008-05-09 08:28 AM
Any One Out Source their CAD work? jekstein CAD Management - General 6 2005-05-28 07:23 PM
