Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2008-11-11, 06:56 PM   #1
kbiv
kbiv is infamous around these parts
Default double-acting solenoid valve
Here's one for you:
You have one physical device that's a three-position pneumatic valve- it has two solenoids, one at either end (push-pull). Now on the electrical schematic we need to indicated somehow that there are two different solenoids that are both part of the same component. On the pneumatic page, we need to show the one valve with the two solenoids (one at either end) and we need to XREF them in such a way that the valve, as a child of the solenoid component, can point to that parent in two different places (one for line xxx where solenoid A is, and one for line xxx where solenoid B is located) It's almost like we need two parents for one child, but we can't do that because there aren't two parents (it's only one component, so the BOM would be screwed up if we tried to show two parents)
If you can't follow me on this I'd be happy to send out a mock-up of how we'd like the end result to look.
Thanks in advance!
MJ
kbiv is offline   Reply With Quote
Old 2009-01-20, 01:58 PM   #2
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
Default Re: double-acting solenoid valve
Hello,
Have you tried creating a child solenoid component? For example: coping HSV1.dwg, save as HSV2 for child and adding plus changing the needed attributes? (add xref and change tag1 to tag2) It might not be that simple as we have not yet incorporated our pneumatics to link with our electrical. It is something I would like to explore.
Please let us know if you come up with a solution.
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
valve MariusvdM Inventor - General 1 2007-04-11 10:29 PM
Manufacturing - Valve rjairath Dynamic Blocks - Sharing 2 2007-02-12 04:26 AM
Holes - Double CSK and Double C'Bored Inventor Wishes INV-001 (Archived) 4 2006-03-28 12:54 PM
Double acting Fire Door bowlingbrad Revit Architecture - Families 3 2005-12-28 06:57 PM
flush valve toilet? mhudson Revit Architecture - Families 0 2005-01-31 04:26 PM
