Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2008-11-13, 11:44 PM   #1
edward.gregory
edward.gregory is infamous around these parts
Default Copying Wire Types
Is there any way to copy the wire types created in one drawing to another drawing? I've tried using the layer states manager but it doesn't copy the wire color and size.
When I started this project my template was not completely evolved to contain the correct wire types, so early sheets of the project are out of sync.
Edward
edward.gregory is offline   Reply With Quote
Old 2009-01-20, 01:40 PM   #2
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
Default Re: Copying Wire Types
Edward
Hi Edward,
Sorry for the delay in response. There are a few of us here yet if you need more information, Autodesk has a wonderful discussion group that is responded to from Autodesk employees. Here we are based on volunteers. Try not to get too discouraged. We all try our best and as I do not know the right answer except that I do not think there is a way. I can try and help you with a “back door”. Hopefully you have solved the dilemma and if so please share with us here.
Ok, for the “back door” approach…I created a script file to create the default layers into the drawing. Next I created a default.wdw file. This file is a project related file for AutoCAD electrical. This file will add the Wire Color/Gauge Label. See the electrical help file for detailed information. I have attached both files for your review as a guild line.
If you have farther questions, please do not hesitate to ask. Or if you would like to see a specific topic discussed in a class format.
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Old 2009-01-23, 11:33 PM   #3
edward.gregory
Hi Reneta,
Thanks for the reply. I ended having to put in the wire types manually to meet a deadline, but this information will definately come in handy in the future.
Edward
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Custom Area Types, Modifying Default Area Types phyllisr Revit Architecture - General 11 2009-09-02 03:38 AM
Annotation subcategories for dimension types and text types narlee Revit Architecture "Original" Wish List (Archived) 5 2006-05-16 07:24 PM
Complex Wall and roof types types Andre Baros Revit Architecture "Original" Wish List (Archived) 0 2004-08-19 11:12 PM
Copying wall types kshawks Revit Architecture - General 2 2004-07-29 10:05 PM
Door Types and Window Types cgrover Revit - In Practice 11 2004-07-23 04:58 AM
