Thread: Glue Command from ACAD R14
    262
    Default Glue Command from ACAD R14
    Hello guys,
    does someone know the equivalent to the "glue" command in R14 to acad 2005?
    This is used to join lines that are split at severals places.
    Thanks !
    150700
    3,439
    Default Re: Glue Command from ACAD R14
    Here is a lisp that will join lines. It will join them if they are separated or overlapping.
    In AutoCAD 2005, the express tool overkill (express-->modify-->delete duplicate items) will also join lines that are overlapping or end to end.
    Not sure if this is exactly what you are looking for.
    13,657
    Quote Originally Posted by brenda.richardson
    Hi
    Where is the LISP?
    Glue.lsp - results from a web search
    Join.lsp - results from a web search
    Have a good one, Mike
    262
    thanks guys !
    I forgot to subcribe duh !
  1. 2014: BIM 360 Glue
    By jtakata341417 in forum Revit Architecture - General
    Last Post: 2015-01-30, 10:08 PM
  2. How to let the user cancel my ACAD command.
    By rene.andreas in forum Dot Net API
    Last Post: 2010-08-30, 12:02 PM
  3. ACAD 2008 Start's Up in a Command
    By KENM.185781 in forum AutoCAD General
    Last Post: 2008-06-23, 08:29 PM
  4. Layout Command - ACAD 2009
    By andersonjg in forum AutoCAD Customization
    Last Post: 2008-05-14, 08:50 AM
  5. ACAD still thinks that a command is active??
    By cdalbey in forum AutoCAD General
    Last Post: 2005-09-30, 12:50 AM
