Welcome, Guest.
| Revit Architecture - General Main discussion area for the latest release of Revit Architecture. |
Thread Tools | Display Modes |
#1 |
In my transformation from ACA to Revit I am trying to achieve a reflected ceiling plan that graphically shows walls that stop AT the ceiling and don't penetrate. My walls are 10' but when I place my ceiling at 10' Revit allows me to add a single ceiling across the entire fit-up but it subdivides the ceiling for each room. How do you show a monolithic ceiling with dashed walls below?
#2 |
Have you tried sketching the ceiling grid instead of automatic ceiling generation?
__________________
Mike Sealander Sealander Architects Ellsworth, ME |
#3 |
#4 | |
HTH,
__________________
Mark Mates Application Engineer |
#5 |
Your walls are actually penetrating the view range's cut plane which is typically 7' 6" and looking up for ceiling plans. This is why they are showing in your ceiling plan so Revit can't ignore them.
__________________
#6 |
Certified AUGI Addict
I would just select all the walls that do NOT penetrate the ceiling, and override the graphics by element in that view. You can change the walls to transparent, and change the cut line type to whatever weight and line style you wish.
__________________
Intern Architect AERC, PLLC Hernando, Mississippi Revit - all up in your voxel space |
#7 |
"Rock-n-Roll Architect"
Hey there,
The simple way is to manually sketch the ceiling using your exterior walls. Good luck Steve |
#8 |
Sketch your ceiling using your exterior walls as the boundary, so the ceiling will go across all the interior wall. if you walls go to 10', change your cut plane to 10' as well, so the cut place goes right over the top of the walls. then, underlay the floor plan, so the interior walls show up as gray, and you go into the vsibility graphics, and change those walls to show up as dashed, with your ceiling over the walls. it should look something similar to the example I have posted here.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Ceiling Grid | ARCHdoc | Revit Architecture - General | 1 | 2008-09-04 08:35 AM |
| Ceiling grid | vipin_nair | AutoLISP | 36 | 2008-02-26 10:16 PM |
| Ceiling Grid | RevitNinja | Revit MEP - General | 2 | 2007-10-16 01:11 AM |
| ceiling grid | aaronwsmith | Revit Architecture - General | 15 | 2006-11-22 09:06 PM |
| Matching ceiling grid to ceiling rendering | Nevine | Revit - Rendering | 1 | 2004-11-27 06:55 AM |
