Bienvenue, Guest.
| Adhérez maintenant | FAQ | Liste des membres | Calendrier | Rechercher | Messages du jour | Marquer les forums comme lus |
Outils de la discussion | Modes d'affichage |
#1 |
ACAD Wish List Administration
Date d'adhésion: 2005-06
Summary: The ability to change properties of a sheet set across multiple sheets.
Description: Turn the DETAILS panel in the Sheet Set Manager palette into a properties palette for titlesheet fields. How Used: If you selected e.g. 3 elevations within the sheet list tab's display, the SSM properties palette would allow you to change all common values e.g. Revision numbers for those particular sheets. Feature Affinity: Sheet Set Manager Submitted By: Gary Murphy on August 8, 2008 |
| Outils de la discussion | |
| Modes d'affichage | |
Discussions similaires
| Discussion | Auteur | Forum | Réponses | Dernier message |
| Edit properties on multiple SSM sheets | jimmy.bergmark | AutoCAD Tips & Tricks | 0 | 2008-09-25 06:21 PM |
| Edit Properties of Multiple Sheets in SSM | acadwishlist | ACAD-007 (Archived) | 0 | 2008-01-09 09:08 PM |
| View/Change Properties in Layer Properties Window | mlongfellow | AutoCAD General | 2 | 2007-12-28 03:37 PM |
| Tip: Aligning Multiple VIews on Multiple Sheets | d.stairmand | Revit Architecture - Tips & Tricks | 5 | 2005-09-08 03:19 AM |
| Duplicate sheets & views on multiple sheets | Chad Smith | Revit Architecture "Original" Wish List (Archived) | 6 | 2005-03-30 04:04 PM |
