Results 1 to 1 of 1
Thread: Use Walls with Surface patterns for curtain walls in Early Design
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Use Walls with Surface patterns for curtain walls in Early Design
    As the Title says this is a huge time saver and looks good too. Just create unique surface patterns for each mullion spacing and you can model and modify towers much more quickly. Once you know what your doing switch to a curtain wall or curtain system.
    Scott D. Brown, AIA
    BECK
  1. AB433-2: Start Early, Finish Early: Using Autodesk® Revit® Architecture During Early Design Stages
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2015-08-07, 03:58 PM
  2. 2013: adding groups of curtain walls to design options
    By kriopelle923935 in forum Revit Architecture - General
    Last Post: 2013-03-27, 06:29 PM
  3. material surface patterns on split regions walls won't update
    By davidthigpen in forum Revit Architecture - General
    Last Post: 2009-03-20, 02:08 PM
  4. Replies: 0
    Last Post: 2009-01-31, 03:55 PM
  5. Curtain Walls: Creating Patterns
    By Steve_Stafford in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-12-03, 02:52 PM
