Welcome, Guest.
Thread Tools | Display Modes |
#1 |
ACAD Wish List Administration
Summary: The ability to plot all layout tabs by right clicking and selecting plot.
Description: Once upon a time, you use to be able to select all of the layout tabs, right click, and plot all at once without having to make a "publish" file. Bring back this feature. It was far less time consuming! How Used: Usually, most people have the same set up for each page. This feature made plotting far less time consuming with less steps. Feature Affinity: Plot Submitted By: Candice LePorte on November 6, 2008 |
#2 |
Certified AUGI Addict
You don't have to make any files now. It's the same procedure, just a slightly different dialog. I don't see how the current method is any more time consuming. You select the layouts, right click, choose Publish, then click OK.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| LDT 2006 - Plot multiple layout tabs with PUBLISH | johnvicki | Land Desktop - General | 6 | 2007-04-25 04:58 PM |
| Publish selected layout tabs from a single DWG file | dzatto | AutoCAD Tips & Tricks | 2 | 2007-01-03 02:38 PM |
| Publish layout tabs and layout tab names to PDF | dfuehrer | AutoCAD Plotting | 9 | 2005-11-09 02:49 PM |
| Fields in layout tabs not updating when using the Publish command | jamie.casile | AutoCAD Fields | 1 | 2005-07-08 02:22 PM |
| Plot Multiple Layout tabs | roy.70844 | AutoCAD General | 4 | 2004-10-07 04:04 PM |
