Welcome, Guest.
| AutoCAD Electrical - General Ask your AutoCAD Electrical questions here! |
Thread Tools | Display Modes |
#1 |
Hi,
I have some problems when I need to show wire annotation on terminal strip. The software does not seems to consider the jumper between two terminals of the same wire, so I get a wire annotation that goes from the first terminal to the other one that is just side by side. Does anyone knows how to eliminate this annotation when I use a jumper? Thanks, Charles |
#2 |
Could you include a picture of what is occurring and what results you would like to see? I do not currently use jumpers but will look into this issue.
__________________
AutoCAD Electrical 2010 (ATP Instructor) soon Autodesk Revit Architecture 2010 AU - 2008 |
#3 |
Thanks for your answer RenetaP!
Here's a picture of what is wrong with the wire annotation when I use jumpers. If you look at the terminal strip P1_DIST with terminal 13212 and N. The wire annotation on the right side are referencing on the terminal strip itsefl. The annotation is "wire number / part destination / pin destination. For me this is representing a wire that goes from a terminal to the terminal next to it instead of a jumpers. Do you understand what I mean? |
#4 | |
I added some pictures and a link to the thread on the attached word document.
__________________
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Purge Annotation Scales That Are Not the Current Active Annotation Scale | acadwishlist | ACAD-010 (Archived) | 0 | 2009-02-01 07:04 PM |
| Jumpers | Cadventurer | AutoCAD General | 3 | 2008-11-04 04:49 PM |
| ACADE 2007 - Jumpers em réguas de bornes | gerson.eng | Português - Inventor / AutoCAD Mechanical / AutoCAD Electrical | 0 | 2007-06-22 03:26 PM |
| Wire | frank.graham | Revit MEP - Wishlist | 0 | 2006-10-25 11:43 PM |
| Wire Glass | jcoe | Revit Architecture - Families | 20 | 2005-08-21 12:34 AM |
