Welcome, Guest.
| Revit Architecture - General Main discussion area for the latest release of Revit Architecture. |
Thread Tools | Display Modes |
#1 |
Hey guys,
Is 1/32" the minimum length in Revit or can I override that?..... Always a warning "Line is Too Short" Suggestions?
__________________
It is much easier to be an Obstacle in Revit then a Resource. |
#2 |
Go to settings / project units. You can set the round-off to a lower value.
When creating the line segment, you'll have to zoom in tight to avoid the error message. |
#3 | |
Certified AUGI Addict
nope, 1/32" is ALWAYS the shortest line you can make, even if project units are set to 1/256" rounding.
__________________
Intern Architect AERC, PLLC Hernando, Mississippi Revit - all up in your voxel space |
#4 |
Why would you want ot make a line shorter than 1/32"??? Most printers and plotters won't allow for that precision anyway.
Another comment, contractors have about 1/2'' tolerance when building a project (think of concrete structure as an example). Do not try to be over-precise in your work anyway. It'S just a loss of time anyway. |
#5 | |
I am doing some detailing using filled regions to outline the window section components. See pic. I am not a fan of doing nested components. And these components are pretty thin.
__________________
#6 |
Try setting your view scale to 1 (full scale), and see if that helps.
Then, once complete, revert back to the scale you want it to be at. Or, do the linework in Autocad, import it, and place your filled region boundary with the pick / tab method. |
#7 | |
You can draw something in CAD with lines shorted than 1/32" and import it in, but once you explode it, any lines shorter than 1/32" will disappear with no warnings or error messages.
__________________
#8 |
Is there any walk-around to what I am tryin' to achieve? I definitely don't want to have it as a nested dwg in my component. Any other method is appreciated....thanks guys
__________________
#9 | |
I don't think there's a workaround for it, unfortunately. Andre Carvalho |
#10 |
Jpg?!!
I guess I have to trim my lines no shorter then 1/32" to get what I want....No big deal....with lines on, it's not that noticeable... Thanks All!!!
__________________
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Lisp routine to list line length and line ID | hlecates | AutoLISP | 6 | 2007-03-21 05:03 PM |
| Minimum Length in formula | noah | Revit Architecture - General | 2 | 2005-09-20 11:11 PM |
| no minimum line size | janunson | Revit Architecture "Original" Wish List (Archived) | 2 | 2004-10-28 11:50 PM |
