Tuesday, February 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > AEC > Revit > Revit Community > Revit - R & D Lounge
 Welcome, Guest.
Login
Revit - R & D Lounge Got an idea for something a Revit user might be interested in, pitch your idea here.
Reply
Thread Tools Display Modes
Old 2009-03-11, 03:22 PM   #1
pkirill
AUGI Director
pkirill's Avatar
pkirill has a bright futurepkirill has a bright futurepkirill has a bright futurepkirill has a bright futurepkirill has a bright futurepkirill has a bright future
Default New Local File Creator Tool
For anyone interested, I built a little local file creation tool in vb.net and put it on our local user group website here: http://www.ramlug.org/?page_id=187. It works in both 32 and 64bit environments.
I allows you to configure your default local folder and some standard "central file renaming" (ie. replace 'central' with 'local', add your initials, the date). It will also allow you to automatically create local subfolders. It also keeps track of the central files you access in a list. There's a help file included to walk you through the initial configuration and use.
Basically it replaces "close local file, navigate to the central file, right click copy, navigate to local folder, delete existing local, right click paste, rename, open, get back to work" with "close local file, open the app, pick central file from a list, click the button to Create Local, get back to work". Just a little something to make life easier.
Please forgive the "branding" - it was the compromise I made to be allowed to make it public...
If you do try it, please leave a comment on the website or here. Hope you find it helpful.
(I've attached the HELP file to give an idea of what it does and how it works.)
__________________
Paul Kirill
Director of Technical & Human Resources
HC Yu and Associates, Consulting Engineers
Richmond, VA
pkirill is offline   Reply With Quote
Old 2009-03-11, 04:57 PM   #2
dbaldacchino
Count (Formula)
dbaldacchino's Avatar
dbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining star
Default Re: New Local File Creator Tool
Hi Paul, thanks for posting. Is the attached zip only for 32 bit OS? I have just a chm file (running Vista 64). I'll check your LUG link too.
__________________
dbaldacchino is offline   Reply With Quote
Old 2009-03-11, 07:36 PM   #3
pkirill
AUGI Director
pkirill's Avatar
OOPS! I forgot to mention that I just posted the chm here to give folks an idea of what it does - the installer is at the LUG website. I wanted to keep it in one place in case I need to update it... We've tested the program here on XP Pro 32 and Vista 64 and it should work in both environments. Let me know it goes!
__________________
Paul Kirill
Richmond, VA
Old 2009-03-12, 12:18 AM   #4
dbaldacchino
Count (Formula)
I did and installed successfully. Looks great, lots of options. I have to digest all of them
__________________
Old 2009-03-12, 03:55 PM   #5
pkirill
AUGI Director
pkirill's Avatar
Since you were the "pioneer" feel free to drop me a note with any questions or suggestions! I already have one to add a "don't show me this again" at the prompt to open the local file after creation. And another (more difficult) to prompt for which version of Revit to open it with...
__________________
Paul Kirill
Richmond, VA
Old 2009-04-01, 05:00 AM   #6
pkirill
AUGI Director
pkirill's Avatar
To those who've downloaded it, I updated the program to v1.9.0. Fixed a bug where if you chose to append the local file with the date, the date wouldn't update from day to day. Now it does!
__________________
Paul Kirill
Richmond, VA
Old 2009-04-22, 07:02 PM   #7
joelkarr
joelkarr is infamous around these parts
Thanks for the tool. We were using a ahk version and just updated to the new patch for Revit MEP 2009. Now the file detaches when it opens. I tried to manually set it to no detach in the journal file but it seems the name of the open file dialog or the checkbox has changed names.
So my question is....
Does your VB.NET program use any journal? I am thinking about trying to replicate it for our purposes in C#
joelkarr is offline   Reply With Quote
Old 2009-04-23, 10:59 PM   #8
pkirill
AUGI Director
pkirill's Avatar
No journal. It runs independant of Revit. At it's most basic, it's a glorified file copier.
Out of curiosity, why would you replicate it in C#?
__________________
Paul Kirill
Richmond, VA
Old 2009-04-27, 06:12 PM   #9
joelkarr
I want to replicate it in C# just because I don't have your source code haha. We would like to give our users a few less options and just hardcode a few things based on our office setup.
If you are willing to share your source, I would be more than happy to give back any migrated to C# version I make.
Old 2009-04-27, 06:22 PM   #10
joelkarr
Actually, I was also trying to add the ability to specify worksets on open which is why I thought you might be using a journal file. But I just reran your tool (which is great by the way) and it seems that you don't have the option to specify worksets yet.
I'm guessing you just open the new local file with revit and that is the end?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Local Files: program to delete local file and create a new local file mailshanegross Revit Structure - General 4 2009-06-03 04:29 AM
Reconcile the differences between your Local File and Central File... saeborne Revit Architecture - General 4 2008-10-03 03:14 PM
Local file mysteriously changing to Central File? nnguyen Revit Architecture - General 13 2006-11-04 10:22 AM
Insert file w/c in a DWG that automatically updates the filename, time and creator jlizann AutoCAD General 10 2006-06-17 10:22 PM
Central file at the office... local file at home Dimitri Harvalias Revit - Worksharing/Worksets 2 2004-08-11 10:05 AM
