Tuesday, February 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > AEC > Revit > Revit Community > Revit - R & D Lounge
 Welcome, Guest.
Login
Revit - R & D Lounge Got an idea for something a Revit user might be interested in, pitch your idea here.
Reply
Thread Tools Display Modes
Old 2009-03-17, 01:07 AM   #1
sfaust
sfaust's Avatar
sfaust is a beam of lightsfaust is a beam of lightsfaust is a beam of lightsfaust is a beam of lightsfaust is a beam of lightsfaust is a beam of lightsfaust is a beam of lightsfaust is a beam of lightsfaust is a beam of lightsfaust is a beam of lightsfaust is a beam of light
Default Keynote Manager Program (Free)
All
We have been developing a stand alone utility to work with Revit's keynote files (Excel and Notepad did not cut it). We are now sharing this application as a free download on our website for the Revit community.
The quick list of features is as follows:
  • Add, Edit, and Delete keynotes in a tree view (like Revit displays them)
  • Automatic File Backup
  • Search Function
  • Automatic Casing
I have also included the readme file as a pdf for a more verbose description of the program .
To download it, go to http://www.emc2architects.com/revit_tools.html and just click the link.
Let me know what you think!
Steve
__________________
Steve
sfaust is offline   Reply With Quote
Old 2009-03-17, 04:28 AM   #2
dbaldacchino
Count (Formula)
dbaldacchino's Avatar
dbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining star
Default Re: Keynote Manager Program (Free)
Thanks Steve! We'll take it for a spin
__________________
dbaldacchino is offline   Reply With Quote
Old 2009-03-17, 04:57 PM   #3
sfaust
sfaust's Avatar
I realized I should mention too that it works off of .NET 2.0 so that is required. That is also what Revit works off of, so that really shouldn't affect anyone.
Lastly, we have tested it in house, but all our computers are 32 bit XP, so that's all it's tested on. It's a pretty simple program and I see no reason it wouldn't run on Vista or 64 bit, but I would be interested to hear someone test different setups...
__________________
Steve
Old 2009-03-17, 09:41 PM   #4
mbalsom
mbalsom appears to be going the right way
Thanks Steve. So far, brilliant !!!!
__________________
MB Drafting
NSW Australia
mbalsom is offline   Reply With Quote
Old 2009-03-18, 02:47 AM   #5
mruehr
mruehr's Avatar
mruehr is going the right waymruehr is going the right waymruehr is going the right way
Thanks Steve
Been waiting for this.
And lots of scope for adding features.
Thanks again
mruehr is offline   Reply With Quote
Old 2009-03-20, 04:46 AM   #6
d.stairmand
d.stairmand has a bright futured.stairmand has a bright futured.stairmand has a bright futured.stairmand has a bright futured.stairmand has a bright futured.stairmand has a bright futured.stairmand has a bright future
Steve
Awesome!!!
One issue - there is the handy automatic backup etc - but if i make a mistake - i cannot undo?
I have to go and retrieve the backup.
__________________
Dwane Stairmand
dsdrafting
www.dsdrafting.com
d.stairmand is offline   Reply With Quote
Old 2009-03-20, 05:59 PM   #7
sfaust
sfaust's Avatar
Dwane. Yes, unfortunately this is true, there is no undo. The reason for this is because of the "Save as you go" nature of it. I used this approach so that multiple team members can work on the file at the same time. I could use a normal open/save process and have an undo, but that would lock everyone else out of the file as soon as the first person opened it. The intended workflow that has worked well in our office is to just keep the keynote manager up while doing the noting in Revit. That way you can use the search functions, etc too.
That being said, suggestion taken, I will look at making a way to perhaps step backward or at least open the backups folder directly from the interface. Thanks for the suggestion.
Lastly, a note for 64 bit users. I had some feedback that the program will hang at certain points on 64 bit systems. I think I have fixed this but am trying to test it, so as soon as I get that going I'll re-post a new version and post here to let you know...
Steve
__________________
Steve
Old 2009-03-25, 07:04 PM   #8
sfaust
sfaust's Avatar
OK all, I've posted a new version (5.1) to our website with several fixes and enhancements including making it viable for many more systems. The current readme is attached here and the list of fixes and adds is at the end. Please re-download and let me know what you think!
Steve
__________________
Steve
Last edited by sfaust : 2009-03-25 at 11:37 PM. Reason: Remove outdated attachment - see next post...
Old 2009-03-25, 11:36 PM   #9
sfaust
sfaust's Avatar
Ok, to anyone who downloaded in the last 4 hours, you may want to re-download. I just caught a bug and fixed it. The Keynote Manager would throw up a button if the text file was moved or deleted , but pressing the button would just cause an error. I have fixed this system so that it notifies you properly if this happens. Also, I added some code that allows it to know if the file name changes while KM is open, and update itself to the new filename.
Sorry for the inconvenience, new readme is attached...
Steve
__________________
Steve
Old 2009-04-03, 08:12 PM   #10
david.199936
david.199936 is infamous around these parts
The second time I hit "Find" It always crashes. Other than that, it looks pretty handy.
david.199936 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
An Ivy Generator Program - Free! stusic DV - Tips & Tricks 4 2008-02-07 03:03 PM
Free compiler to program in C++? clovis ARX 6 2006-08-15 07:12 AM
Keynote and Tag - Attached vs. Free end 4christo4 Revit Architecture "Original" Wish List (Archived) 0 2006-05-16 03:55 AM
Free 3D Rendering Program Crosseyed Revit - Rendering 2 2006-04-15 10:16 PM
Free image program Glenndp Software 8 2005-11-21 08:32 PM
