Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2009-04-02, 11:04 AM   #1
arve.naestby
arve.naestby is infamous around these parts
Default Publish problem
Hello
I am running AutoCAD Electrical 2009.
When I want to publish a set of drawings I run into this problem.
I publish the project and choose A4 format in "Detailed Plot Configuration Mode"
from generic list. Windows default printer is the correct one. But when I choose A4 it always uses XPS Document printer.
If I pick "Use Drivers Default", then it prints on the printer, but I have to manually choose format at the printer. This is lots of extra when printing 40 docs
Howcome my choice of A4 format changes my selection of printer?
arve.naestby is offline   Reply With Quote
Old 2009-04-07, 03:41 PM   #2
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
Default Re: Publish problem
Originally Posted by arve.naestby View Post
Hello
Printing is a whole other monster. You might want to check the AutoCAD Plotting forum. http://forums.augi.com/forumdisplay.php?f=34 My method is still from way back-2005, updated in 2007, and works for me. We currently are using 2008 so I am not sure what changes might have been made in 2009. Attached is how I create batch plots of a drawing set. I was not too proficient with AutoCAD electrical 2007 Publish/Plot Project. Attached is a write up on it that might work.
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Publish to Web Problem kevinc.117928 AutoCAD Customization 0 2008-09-20 02:13 AM
Publish problem with 2009 clintonc AutoCAD General 3 2008-08-08 08:05 PM
NAVISWORKS PUBLISH PROBLEM sam_ctlim NavisWorks - General 1 2008-07-18 09:27 PM
Project publish to DWF problem? gwnelson Revit - Platform 2 2008-04-22 04:41 PM
Problem Batch Plotting (Publish) w/ Xerox 8850 tom.masters AutoCAD Plotting 5 2004-07-29 03:19 AM
