sblackburn
I am wondering if anyone here has found a solution to the problems the "Datalink" command has with formatting. In searching the forums here it seems to be a limitation with the software. We have several Excel tables linked into AutoCAD with the datalink command, and even doing simple things like adding a few rows in the Excel file seems to throw the formatting off in the updated table in AutoCAD. Let alone more complicated formatting changes. This makes the command all but useless, since it is easier to re-link the file than make all the necessary changes in AutoCAD. And then we might as well be using OLE. Has anyone solved this issue? Does AutoCAD 2010 fix these formatting issues? Thanks for any help.
Steve Blackburn
Frost Engineering
