AutoCAD Architecture 2024- Door Tags
Hi All,
I am using AutoCAD Architecture 2024. I am trying to Annotate Doors, The door tags are not auto-sequenced. The tag was custom as per office standard made a lot earlier. Is there a setting in the file or to the tag created that can enable the auto-sequencing of doors as selected?
Re: AutoCAD Architecture 2024- Door Tags
You might want to share a dwg with the tag in it so the style can be analyzed.
ACA has a renumber tool that allows you to renumber your door tags so they are in sequential order. Have you tried that?
What does it do and what are you expecting?
Select a tag and then right click to select similar.
Swap to an OOTB tag and does it do the same thing?
undo.
Tags just reference data so if it's custom data it could be a problem with your custom data.
I find sometimes dependencies in systems fail because one of the data sets is not set up correctly.
By sequencing you seem to be expecting it to number how you want but I would think, if you've applied the tag to Multiple it might do that in the order that the doors were created.
So often I need to renumber using the PROPERTYRENUMBERDATA command to then renumber the property in the order that I want.
No What is that tool and how is it used? Thank you
