Pipe labels in sheet manager 2005
Good afternoon everyone! Does anybody know of issues with 2005 Civil Design sheet manager pipe labels?
I am producing labels through sheet manager for my plan and profile sheets. I'm not working in 3d yet. Everything looks good until I go to check my inverts. When I check them by hand they do not match what is labeled. My length is 2d in my settings box. Does anyone have any ideas why it is doing this? I've checked everything I can think of.
Thanks ahead of time for any help:-)
Stacie
RE: Pipe labels in sheet manager 2005
When you calc them by hand, are you going from station to station and then multiplying the distance with the slope? Or are you taking the length that is labelled on the pipe itself and using that to calc your inverts?
I went by the length and slope to check inverts.
Last night I found that the length in my pipe editor is not matching the length labeled in sheet manager. I have not figured out why it's doing this.
I should have explained the way I checked my inverts a little more thoroughly. I started with the invert at the top or bottom of a run. Then I just walked through the run using the labeled distance and slope. When this didn't match, I printed out the pipe editor length and slope for each run. The length did not match the labeled length. If I replace the sheet manager length with the pipe editor length, all of my inverts look good.
What is the 3D length of the pipe compared to what sheet mgr is labelling them at?
