Hey there,
See my reply here. Sorry, forgot to quote you so you knew that I was responding to your question.
Printable View
The true answer is they were given Reflex as part of their severance together with 250 hours of each of the main programmers.
The core system is almost identical. I am happy to show the old reflex manuals which show this.
you actually still don't own Revit, you lease it. Try to sell it yourself, its illegal to resell an Autodesk Product. you have never owned an Autodesk product and you never will, you lease the license and if you don't subscribe and stay current, it just stops getting supported. I subscribed to Revit before Autodesk - worked on a house, and spent alot of time on the phone with tech support - Revit was really talking smack about Autodesk and "owning them". I wished they had stayed the course and never got in bed with AD. Now Revit users are stuck paying subscriptions to Autodesk as they try to make it AutoCad. Whatever happened to architectural software for architects by architects?
Thank you, jondotdot;
I have always said the same thing as referenced by others on this thread. In my view, Revit is a developed version of ProReflex making it easier to create drawings, especially re-engineering and automating View Objects backwards from placing Section and Elevation lines, and allowing the outlines of objects to be edited rather than having to start again (including Slabs, Walls, Ceilings, etc) and letting Walls join Slabs and Roofs as well as Doors and Windows. I can also see that the ProReflex idea of Draw>Line>Assemble>Exchange is the basis of Sketching things in Revit, at first sight a key difference between the programmes. In fact, I would say that the key differences between the programmes are in the things that you still can't do in Revit, ProReflex Shells for example, which is surprising 17 years on. How about rendering Plans, Sections and Elevations; is that possible yet in Revit ?
I am not a computer programmer and don't understand how Leonid Raiz could say that Revit and ProReflex don't have a single line of code in common, especially considerring both were written in C++, and that they have a common wall join bug, where multiple wall joins at acute angles to a fixed point leaves a mess, perhaps as it would in reality, you may say.
As for setting up a separate company to develop Revit when they should have been working on ProReflex, perhaps true, but didn't Charles River Ventures also back PTC themselves when they started up, sponsoring another Russian mathematician as Googling the origins of PTC suggests ? Perhaps both PTC and Revit were really Charles River Ventures' companies all along ? :shock:
PS: I should add that I only came across this thread after discussing what I thought had been the origins of BIM with Sonata, subsequently Reflex and ProReflex. I was prompted to investigate a few days later and here I am . . . . a blast from the past indeed.
Actually, neither the concepts nor the code base of Revit were derived from Pro/Reflex. The most recent issue of AECMAGAZINE included my letter revealing the real relationship between Revit and Pro/Reflex. It may be seen here: http://aecmag.com/59-features/1352-c...history-of-bim.
It is interesting to see this topic come up again. I recently started a blog and did a quick write up on this: https://bimchapters.blogspot.com/201...-creation.html
Here’s another recently published article in AEC Magazine regarding the same subject:
https://aecmag.com/features/explorin...istory-of-bim/
