Autocad 2010 unable to change linetype on ribbon
Hi there,
I am unable to change the linetype, linewieght or layer via the ribbon. I need to go through the properties toolbar to change these settings - which is rather annoying! Any clues as to what is wrong? It must be a setting I have missed.
Cheers,
Chad
Re: Autocad 2010 unable to change linetype on ribbon
CHAD.BEDARD847126
What happends when you try to change them?
Does it happen in every drawing?
Is your Layer Manager Palette open? It sometimes causes this issue, with lots of layers. Try closing it, or even set LayerDlgMode = 0, so it uses the old Layer Dialog instead.
i have the same problem. when i select an object in the drawing, the properties in ribbon doesnt change. and if i try to change any of the properties for the object using ribbon... nothing happen to the object and the properties remain the same. please help...
System Variable : PICKFIRST < set to 1>
