VB.Net - Print Paperspace to PDF
Dear All,
I can not figure out how to print my autocad drawings - all located in a same folder - to pdf from a Visual Studio App.
So far, I can open a Autocad Drawing, but after that, can for activated the particular PaperSpace (called "A3 - ENGLISH").
The PC3 file is Herve.pc3 and Herve.pmp.
Here below the code I have but not working. I look on google but still can not figure out how to di it.
Thank you
Herve
Imports System
Imports System.IO
Imports System.Text
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports System.Data.SqlClient
Imports System.Data.OleDb
Imports Microsoft.Office.Interop
Imports System.Runtime.InteropServices
Imports Excel = Microsoft.Office.Interop.Excel
Module Mdl_Print
Dim AcadApp As AcadApplication
Dim AcadDoc As AcadDocument
Public Sub PDF_Print()
Dim dirInfo As New DirectoryInfo(Frm_Main.LblFolder1.Text)
Dim fileInfo As FileInfo
Dim AcadApp As AcadApplication = New AcadApplication
AcadApp.Visible = True
AcadApp.WindowState = AcWindowState.acMax
Dim success As Boolean = False
For Each fileInfo In dirInfo.GetFiles("*.dwg") 'dwg for Autocad
AcadDoc = AcadApp.Documents.Open(fileInfo.FullName)
Dim oSS As AcadSelectionSet
oSS = AcadApp.ActiveDocument.SelectionSets.Add("oSS")
oSS.Clear()
Try
Dim ftype(0) As Int16
Dim fdata(0) As Object
ftype(0) = 410 'layout
fdata(0) = "A3 - ENGLISH"
oSS.Select(AcSelect.acSelectionSetAll, , , ftype, fdata)
Dim objPrefFiles As AcadPreferencesFiles
Dim PC3PathOld As String
Dim PC3PathNew As String
Dim PMPPathOld As String
Dim PMPPathNew As String
Dim PtConfigs As AcadPlotConfigurations
Dim PlotConfig As AcadPlotConfiguration
Dim PtObj As AcadPlot
Dim BackPlot As Object
'Set the preferences object
objPrefFiles = AcadDoc.Application.Preferences.Files
'Get the current Printer Config Path (pc3)
PC3PathOld = objPrefFiles.PrinterConfigPath
MessageBox.Show(PC3PathOld, "old Printer Config path (pc3)")
objPrefFiles.PrinterConfigPath = "C:\Users\ROBERT\Documents\Deb + Herve + Will\B - Herve\Technip\Autocad\1st project\OpenExcel\PC3 Files"
PC3PathNew = objPrefFiles.PrinterConfigPath
MessageBox.Show(PC3PathNew, "new Printer Config path (pc3)")
'Get the current Printer Desc Path (pmp)
PMPPathOld = objPrefFiles.PrinterDescPath
MessageBox.Show(PMPPathOld, "Printer Desc Path (pmp)")
objPrefFiles.PrinterDescPath = "C:\Users\ROBERT\Documents\Deb + Herve + Will\B - Herve\Technip\Autocad\1st project\OpenExcel\PMP Files"
PMPPathNew = objPrefFiles.PrinterDescPath
MessageBox.Show(PMPPathNew, "Printer Desc Path (pmp)")
PtObj = AcadDoc.Plot
AcadApp.ActiveDocument.AcPlotType.acExtents()
PtConfigs = AcadDoc.PlotConfigurations
''Add a new plot configuration
PtConfigs.Add("PDF", False)
''The plot config you created become active
PlotConfig = PtConfigs.Item("PDF")
''Use this method to set the scale
PlotConfig.StandardScale = AcPlotScale.acScaleToFit
''Updates the plot
PlotConfig.RefreshPlotDeviceInfo()
'Here you specify the pc3 file you want to use
PlotConfig.ConfigName = "Herve.pc3"
'You can select the plot style table here
PlotConfig.StyleSheet = "monochrome.ctb"
'You can select the Scale Line Weight
PlotConfig.ScaleLineweights = True
'Specifies Paper Size
PlotConfig.CanonicalMediaName = "ISO_A3_(420.00_x_297.00_MM)"
'Specifies whether or not to plot using the plot styles
PlotConfig.PlotWithPlotStyles = True
BackPlot = AcadDoc.GetVariable("BACKGROUNDPLOT")
AcadDoc.SetVariable("BACKGROUNDPLOT", 0)
'Updates the plot
MessageBox.Show("scale" & PlotConfig.StandardScale)
MessageBox.Show("canonical media name" & PlotConfig.CanonicalMediaName)
MessageBox.Show("config name" & PlotConfig.ConfigName)
MessageBox.Show("plot type" & PlotConfig.PlotType)
MessageBox.Show("scale line weight" & PlotConfig.ScaleLineweights)
'Now you can use the PlotTofile method
If PtObj.PlotToFile(Replace(AcadDoc.FullName, "dwg", "pdf"), PlotConfig.ConfigName) Then
AcadDoc.Utility.Prompt(vbLf + "PDF Was Created")
Else
AcadDoc.Utility.Prompt(vbLf + "PDF Creation Unsuccessful")
End If
'If you wish you can delete the plot configuration you created programmatically, and set the 'BACKGROUNDPLOT' system variable to its original status.
PtConfigs.Item("PDF").Delete()
PlotConfig = Nothing
AcadDoc.SetVariable("BACKGROUNDPLOT", BackPlot)
objPrefFiles.PrinterConfigPath = "C:\Users\ROBERT\AppData\Roaming\Autodesk\AutoCAD 2014\R19.1\enu\Plotters"
objPrefFiles.PrinterDescPath = "C:\Users\ROBERT\AppData\Roaming\Autodesk\AutoCAD 2014\R19.1\enu\Plotters\PMP File
oSS.Clear()
If AcadDoc.Saved Then
AcadDoc.Close(False)
End If
AcadDoc = Nothing
AcadApp.Quit()
AcadApp = Nothing
success = True
Catch ex As Exception
MsgBox(ex.Message + vbLf + ex.StackTrace)
success = False
End Try
' AcadDoc.Close()
AcadDoc = Nothing
' AcadApp.Quit()
Next
AcadApp.Quit()
End Sub
