1 Attachment(s)
my block dinamic hatch can not change length and angle
i have code to dinamic block using hatch but while distance1 is changed and angle1 is changed
my hatch can not update distance1 and angle1
please help every body
Sub test1()
Dim j As String, Sudut As Double, jarak As Double
Dim a As AcadBlockReference
jarak = ThisDrawing.Utility.GetString(1, vbCrLf & "Masukkan Jarak: ")
x = ThisDrawing.Utility.GetPoint(, "Klik titik awal")
jarak = CDbl(jarak)
Sudut = Atn(1)
Set a = ThisDrawing.ModelSpace.InsertBlock(x, "a1", 1, 1, 1, 0) 'a1 ganti dengan nama blokc
If a.IsDynamicBlock = True Then
Props = a.GetDynamicBlockProperties
For Index = LBound(Props) To UBound(Props)
Set prop = Props(Index)
If prop.PropertyName = "Distance1" Then
prop.Value = jarak
ElseIf prop.PropertyName = "Angle1" Then
prop.Value = Sudut
End If
ThisDrawing.Regen acAllViewports
Next Index
End If
End Sub
1 Attachment(s)
Re: my block dinamic hatch can not change length and angle
this is my image please help me what is wrong
Attachment 107610
3 Attachment(s)
Your hatch was not included in the stretch action. I redefined it by modifying the stretch action's selection set and doing a crossing window using points 1,2. After that, the code worked...with modifications. You had 4 variables that were not dimensioned. If you add Option Explicit to the top of each module as shown, the IDE will notify you if you try to use a var that has not been dim'ed. If you set Require Variable Declarations in your VBA options, it will add Option Explicit to new modules.
