Re: Content Center Library
before today i think i have this problem due to my system's restrictions as we work in a domain & we are alloted as a restricted user. but today i called my system maintenance administrator 7 tried to check whether the content center library works or not. all in vain. it doesnt started & again same message appeared as in my user login.
can any one give autodesk's toll free no. or any kind of help. so this problem can be resolved as i have to complete many projects in inventor.
please help me.
thanks in advance.
-LALIT
One suggestion I would like to make is that you check the "File Settings" under the "Application Options" menu. Make sure that the "Default Content Centre" files location is correct?
Regards.
Dave
I had another thought last night!
Are you using Vault? If you are, and forgive me if my memory of this is not be what it should be, I believe you have to activate the Content Centre Library within Vault. Vault assumes multiple users and you have to point to the location of the files for those users. Go to the Vault server and check this out.
Sorry if this is a bit fuzzy, I am not a Vault expert, and I may be off the mark with this as I have only ever used it once.
Regards.
Dave
