AutoCAD 2005 - Shouldn't layers states transfer from one file to another
AutoCAD 2005
It must be Monday. Shouldn't layers states transfer from one file to another?
Example:
File A
Visretain: 1
Has File B xref'd into it as either an overlay or attachment (doesn't seem to matter).
Layer Name: File B|Slab
State: Frozen
File B
Layer Name: Slab
State: Thawed
File C
Has File A xref'd into it as either an overlay or attachment.
Visretain: 0
Shouldn't layer Slab still be frozen in File C since it's frozen in File B?
I've audited and purged everything to death....
Thanks for your help,
Corey
RE: AutoCAD 2005 - Shouldn't layers states transfer from one file to another
Originally Posted by cgerhardt
AutoCAD 2005
<SNIP>
Hi
Take a look at the following...
RE: Layer states - can we save the states out ?
Have a good one, Mike
But with visretain set to zero (0), shouldn't a change to layer state in an xref be reflected with the xref is reloaded?
I'm trying to work around not saving layer states if there are the same in both drawings. So if I change a layer's linetype in the source drawing, the destination file when reloaded will reflect the new linetype. I was hoping this would work with visretain set to zero.
Hi
Just checking here...
Do you mean Layer State(s).
OR
Layer properties.
The above are two very different things.
If you mean Layer properties, then yes with VisRetain set to 0 ( zero ), Layer properties that change within the actual Xref file should be seen when the Xref in question is Reloaded.
I guess I'm asking two questions here regarding:
- Layer's properties such as linetype
- Layer's state such as frozen.
According to the help file visretain controls:
"Controls the visibility, color, linetype, lineweight, and plot styles"
Would the AutoCad 2005 service pack fix this problem?
Hmm, for some reason I hoped any layer property changes would filter through the xref chain.
Therefore visretain only effects the current drawing.
So if A in xref'd into B and B is xref'd into C, any layer changes of A in B are not transfered to C. A in C will look like the original A and not the A in B.
C will load both A and B as individual Xrefs, even though A only exists as an XREF in B.
