1 Attachment(s)
AutoCAD 2013 - DWG to PDF
I am having an issue when I use dwg to pdf option. When I preview it it looks perfect. When I view the pdf its not what was previewed. I created mark/schedule boxes and detail bubbles with solid had patterns so I don't have to trim anything that is behind it. This has worked on previous versions of CAD. Anyone please help????? THANK YOU!!!!!
Re: AutoCAD 2013 - DWG to PDF
I just printed the dwg file straight to my printer and printed just fine. Why is dwg to pdf having an issues?
Are you talking about the lines across the "FJ1" boxes?
what color the solid hatch? suggest using TrueColor 255,255,255
and of course, verify Draworder so all the linework is below
@jaberwork and cadtag - Yes the lines across fj1. It comes out correct when I preview it before creating the pdf and when I print them to my printer.
cadtag
can you answer these questions?
i got it to work now. thank your for your help though. it was just a setting i changed that i had for 2006 but changed it to the default since now im on 2013.
hcadang
Thanks; please tell us WHAT setting for the benefit of future visitors.
In fact, pdf sometiome is unstable, my suggestion is that in order to be sure nothing gonna be wrong, you can convert the pdf to word document or other stable formats, that's my way to solve the problem.
