How to mark/tag any element without changing its properties.
Hi!
Is it possible to add some tag/mark to an element in the drawing?
For example: there is a set of lines on the same layer in the drawing . Some of them are very important. I want to permanently tag them, so that i could easily identify these elements (using autolisp) with other opening session of the drawing. I want this tag to be invisible in the model space (it could be visible in the 'properties' panel). I do not want to change any properties of the elements (layers, lineweights etc.). I do not want to add any new elements to the drawing (notes, attributes etc.). I mean some kind of an attribute connected to element but without creating a block.
Adding some suffix to handle value could be perfect, but I think changing the handle value is impossible. Am I right?
Thank you for Your help in advance.
Re: How to mark/tag any element without changing its properties.
If you have Map or one of it's verticals you can. Otherwise you could group them or reference them in a field.
marko_ribar
How about XDATA ?
Thank You! That's what I was looking for!
sanch3z
Yes Xdata can be a good way, for exemple
Affect your application to object
((lambda ( / app_name js n ent dxf_ent x_data)
(setq app_name "PERSONAL_ENTITIES")
(regapp app_name)
(princ "\nSelect objects")
(setq js (ssget))
(cond
(js
(repeat (setq n (sslength js))
(setq ent (ssname js (setq n (1- n))) dxf_ent (entget ent))
(setq x_data (list -3 (list app_name (cons 1005 (cdr (assoc 5 dxf_ent))))))
(entmod (append dxf_ent (list x_data)))
Select only your entities and grip them
((lambda ( / app_name js)
(setq js (ssget "_X" (list (list -3 (list app_name)))))
(sssetfirst nil js)
Remove your entities of one selection gripped or previous
((lambda ( / js js_app n ent)
(or (setq js (ssget "_I")) (setq js (ssget "_P")))
(setq js_app (ssget "_X" (list (list -3 (list app_name)))))
(cond
((and js js_app)
(repeat (setq n (sslength js_app))
(setq ent (ssname js_app (setq n (1- n))))
(ssdel ent js)
(sssetfirst nil nil)
(sssetfirst nil js)
