Revit Arch 2012 - broken shared parameters in sheets
Hi, I have previously set up a sheet using shared parameters within a titleblock and everything was / is OK. I have since added this sheet to another project (which references the same shared parameter file) and I get '?' displayed for each label (shared parameter) placed instead of an editable field.
Using the Labels 'Properties' | 'Edit' | 'Edit Family Parameter' in the title block family editor to bring up the 'Parameter Properties' dialogue box it correctly references the shared parameter... I'm stumped!
Any ideas?...
Ady
Re: Revit Arch 2012 - broken shared parameters in sheets
What info is being referenced in the shared parameters? (project or sheet specific)
Try reloading the shared parameter info, after the title block is loaded.
