2 Attachment(s)
Autocad Installation HUGE problem
Dear Friends,
please help to solve a problem appearing while installating AutoCAD 2008 LT!
DWFViewer cant be installed and as a result Autocad cant be installed too.
in the attachment couple of photos with errors and error messages are below.
please help me!
1 Attachment(s)
Re: Autocad Installation HUGE problem
also here is a message error content:
Windows MSI lists error code 1639 as "incorrect command line argument". That's probably not much help, but its all I can give you. Autodesk doesn't list the problem in their knowledge base.
You might try seeing if there is an option in the setup not to install the viewer. Then after LT installs, you could go to Control Panel>Programs and try to add the viewer.
You may need to contact your reseller for technical support.
thank you everybody who participate!
i solve a problem,
when you registering you program dont use " " in the name of company!
have a nice day!
