Lisp to "Display plot styles" on open
Hi all! I'm hoping someone might be able to help me with a Lisp routine. I would like to have a Lisp that could change all layouts to "Display plot styles" on open. I have a couple Lisps already that get me pretty close but I was hoping that someone would be able to combine the two somehow.
I'm running Civil3D 2011 on Win7-64
I found this Lisp somewhere on this forum. I think originally it unchecked the "display plot styles" but I changed it to do the opposite. I turned it into a button, but its a manual button press and it only works on the current tab.
(defun pstyleDOshow (/ doc layoutobj)
(setq doc (vla-get-activedocument
(vlax-get-acad-object)
layoutobj (vla-get-activelayout doc)
(vla-put-showplotstyles layoutobj :vlax-true)
(vla-regen doc acAllViewports)
(mapcar 'vlax-release-object (list layoutobj doc))
(princ)
Then I have this Lisp to lock all viewports in an drawing automatically after opening a drawing. I just add this to my startup suite and it works great!
;;;VPLOCK.lsp locks all viewports automatically when opening a drawing
;;;no idea who wrote it
(defun vplock (yesno / ss lock x obj)
(vl-load-com)
(if (setq ss (ssget "X" '((0 . "VIEWPORT")(-4 . "/=")(69 . 1))))
(progn
(if (= "y" yesno) (setq lock :vlax-true)(setq lock :vlax-false))
(setq x 0)
(while (< x (sslength ss))
(setq obj (vlax-ename->vla-object (ssname ss x)))
(vla-put-displaylocked obj lock)
(setq x (1+ x))
(princ)
(vplock "y")
So I don't know if a combination of these two would work, but I thought I'd include both just in case it helps. Ultimately what I need is a way to change all viewports in a drawing to "display plot styles" every time I open a drawing. Is this possible? I've been trying to figure this out on my own for a while but I'm not that great at programing so I haven't been able to make it work correctly. I would really appreciate any help on this. Thanks!
Re: Lisp to "Display plot styles" on open
Try adding this to your startup suite:
(defun showpstyle ( / DOC LAYOUTS)
(setq doc (vla-get-activedocument (vlax-get-acad-object))
layouts (vla-get-layouts doc)
); setq
(vlax-for n layouts
(vl-catch-all-apply 'vla-put-showplotstyles (list n :vlax-true))
); vlax-for
(mapcar 'vlax-release-object (list layouts doc))
(princ)
); defun
(showpstyle)
Thanks gharvey for the quick reply! That worked perfectly! You're awesome!
Hi, GHarvey. Is there any way to write this so it will effect all paper space layouts and exclude the model layout. When I run it it changes all of my colors that are set to black/white (Pen 7) to white in model space.... My hope is to see model space in color, but paper space as a plot preview... (In Black) Thanks in advance!
Try the following revision...
); setq
(vlax-for n layouts
(if (/= "Model" (vla-get-name n))
); if
); vlax-for
(princ)
); defun
(showpstyle)
Couple of things....
Unless I am overlooking something (which is entirely possible), there's no need to call vl-Catch-All-Apply when setting an Object's Property (in this case a Boolean), given that you've hard-coded an allowable value (in this case :vlax-True).
I would, however, recommend that one do so (that is, to use vl-Catch-All-Apply) if passing a parameter to the Object's Property as a value; just not needed here IMO.
Also, one need not release internal Object's; only external/interface Objects.
(defun c:ShowPlotStyles ( / acDoc)
(vlax-for oLayout
(vla-get-layouts
(setq acDoc
(if (/= "Model" (vla-get-name oLayout))
(vla-put-showplotstyles oLayout :vlax-true)
(vla-regen acDoc acAllViewports)
(princ)
Separately, this could easily be expanded to incorporate a bit-coded setting, either drawing data (via XRecord?), or registry data to allow one to programmatically toggle the ShowPlotStyles Property value at drawing open, and/or while in session if desired
Psuedo system variable:
0 = All Layouts do not display plot styles
1 = All Layouts display plot styles, except for Model
2 = All Layouts display plot styles, including Model
Thank You!! GHarvey & RenderMan
GHarvey
); setq
(vlax-for n layouts
); vlax-for
(princ)
); defun
(showpstyle)
this lisp does not response when i load. can anyone help me
BlockBox - could it be done as a toggle? (I'm thinking single icon on the tool palette to toggle back and forth). Thanks as always!
BlackBox
(vlax-for oLayout
(vla-get-layouts
(setq acDoc
(princ)
jpcadconsulting347236
Try this:
(defun c:ShowPlotStyles (/ acDoc ctab)
(vl-load-com)
(setq acDoc (vla-get-activedocument (vlax-get-acad-object))
ctab (vla-Item (vla-get-layouts acDoc)(getvar "ctab"))
(vlax-for oLayout (vla-get-layouts acDoc)
(if (= (vla-get-ShowPlotStyles ctab) :vlax-true)
(vla-put-showplotstyles oLayout :vlax-false)
(princ)
Works like a charm! Thanks.
BTW - reactors are making my head hurt...
