Check if Custom Drawing Property exists
Is there a way to run a test to determine if a particular custom property exists. I am using this to modify my autoplot to file program, however if the custom property does not exist, I get an error and the drawing will not plot. I would like to be able to check if the property exists, and if it does not, open the plot dialog box.
RE: Check if Custom Drawing Property exists
Originally Posted by ccowgill
Is there a way to run a test to determine if a particular custom property exists. . .
Probably yes, but you must know what to search for.
In your case, what is custom property ?
: ) Happy Computing !
kennet
Huh!
Kennet I am do not late today :)
(defun IsCustomExist (custom) ; string
(vl-load-com)
(setq acapp (vlax-get-acad-object)
adoc (vla-get-activedocument acapp)
docinfo (vla-get-summaryinfo adoc)
(setq check nil)
(if (and (eq 'str (type custom))
(not (eq "" (vlax-get-property docinfo custom)))
(setq check T)
;Call (IsCustomExist "LastSavedBy")
~'J'~
kennet
PLOTFILE is the custom property. It is not in a particular location so vla-getbyindex wont work
Wasn’t that an answer to your question ?
kennet
BTW the default plotfile location is saved in the registry, not in the drawing.
Let me try to rephrase the question.
this is the error message I get if the custom property "PLOTFILE" has not been created
Error: Automation Error. Key not found
I would like the following to happen when the key is not found
(initdia)
(command "_.PLOT")
I need to know how to check to see if "PLOTFILE" exists in the custom drawing properties.
This is my entire code, it works fine right now, other than when there is no property "PLOTFILE" in the cross section sheets, then I get the above error
(command "undefine" "plot")
(defun C:PLOT (/ ss App Doc Dwgprops dname name file)
(vl-load-com)
;; L o c a l F u n c t i o n s
;; error function & Routine Exit
(defun *error* (msg)
(if
(not
(member
msg
'("console break"
"Function cancelled"
"quit / exit abort"
(princ (strcat "\nError: " msg))
) ; endif
(restore_sys_vars) ; reset vars
;; Function to save system variables in global variable
;; call to function
;; (save_sys_vars '("CMDECHO" "FILEDIA"))
(defun save_sys_vars (lst)
(setq *sysvarlist* '())
(repeat (length lst)
(setq *sysvarlist*
(append *sysvarlist*
(list (list (car lst) (getvar (car lst))))
(setq lst (cdr lst))
;; Function to reset system variables
(defun restore_sys_vars ()
(repeat (length *sysvarlist*)
(setvar (caar *sysvarlist*) (cadar *sysvarlist*))
(setq *sysvarlist* (cdr *sysvarlist*))
(setvar "cmdecho" 0)
(setvar "filedia" 0)
(SETQ spellselect
(SSGET "all"
(LIST '(-4 . "<AND")
(CONS 410 (GETVAR "ctab"))
'(-4 . "<NOT")
'(-4 . "<AND")
'(0 . "INSERT")
'(2 . "M*")
'(-4 . "AND>")
'(-4 . "NOT>")
'(-4 . "AND>")
) ;end of LIST
) ;end of ssget
) ;end setq
;(if (/= spellselect nil)
;(COMMAND "SPELL" spellselect "")
;);end if
(setq spellselect nil)
(setvar "expert" 5)
(setq dname (getvar "DWGPREFIX")
filename (getvar "DWGNAME")
(setq dir (strcat dname "PLOTS\\"))
(vl-mkdir dir)
(setq extA (getvar "ctab"))
(if (/= (setq ss (ssget "_x"
(list '(-4 . "<and")
'(0 . "insert")
'(2 . "TBL8,TBL13,TBL14,TBL15,CTLB")
(CONS 10 '(0 0 0))
'(-4 . "and>")
) ;end list
) ;end ssget
) ;end setq
nil
) ;end =
(PROGN
(if (wcmatch extA "SH#*")
(progn
(setq file (strcat dir extA ".PLT"))
(setq
tfresult
(dwpMsgbox
"WIGHTMAN CAD WARNING"
(strcat "Do you wish to plot directly to file?"
"\n"
"(If yes click ok if not click cancel)"
vlax-vbOKCancel
vlax-vbExclamation
) ;end dwpmsgbox
) ;end setq
;;PLOT DIRECTLY TO FILE?
(if (= tfresult 1)
(progn
;(setvar "filedia" 0)
(command "-psetupin" "page setup" "*")
'(0 . "insert")
'(2 . "TBL15")
'(-4 . "and>")
) ;end list
) ;end ssget
) ;end setq
nil
) ;end =
(setq pagesetup "30x42PS")
) ;end if
(if (/= (setq
ss
(ssget "_x"
(cons 0 "insert")
(cons 2 "TBL14,TBL8,TBL13,CTLB")
'(-4 . "and>")
) ;end list
) ;end ssget
) ;end setq
nil
) ;end =
(setq pagesetup "24x36PS")
) ;end if
(command ".-PLOT" "N" ;Detailed plot configuration? [Yes/No] <No>: N
"" ;Enter a layout name or [?] <Layout1>:
pagesetup ;Enter a page setup name <>:
"" ;Enter an output device name or [?] <current>:
"y" ;Write the plot to a file [Yes/No] <N>: y
file ;Enter file name <\\maverick\engineering\x5405\RCp01001-Layout1.PLT>:
"y" ;Save changes to page setup [Yes/No]? <N> n
"y" ;Proceed with plot [Yes/No] <Y>:
) ;end command
) ;end progn
(progn ;if you wish not to plot directly to file
(initdia)
(command "_.PLOT")
) ;end progn
) ;end tfresult if
) ;end progn for wcmatch t
(progn ;end if for wcmatch t
(if (= (wcmatch filename "rc#*") t)
(progn
(setq App (vlax-Get-Acad-Object)
Doc (vla-Get-ActiveDocument App)
DwgProps (vla-Get-SummaryInfo Doc)
) ;end setq
(setq name "PLOTFILE")
(vla-GetCustomByKey DwgProps name 'ext)
(if (/= ext "")
(progn
(setq
file (strcat dname "PLOTS\\" ext ".PLT")
(setq
tfresult
(dwpMsgbox
(strcat
"\n"
) ;end strcat
vlax-vbOKCancel
vlax-vbExclamation
) ;end dwpmsgbox
) ;end setq
(if (= tfresult 1)
(progn
(if (/= (setq
ss
(ssget
"_x"
(list
'(-4 . "<and")
(cons 0 "insert")
'(-4 . "and>")
) ;end list
) ;end ssget
) ;end setq
nil
) ;end =
(setq pagesetup "24x36MS")
) ;end if
pagesetup
) ;end command
) ;end progn tfresult = 1
(initdia)
(command "_.PLOT")
) ;end progn
) ;end tfresult if
) ;end progn for ext /= nil
(progn ;no drawing property
(initdia)
(command "_.PLOT")
) ;end progn
) ;end if
) ;end progn for wcmatch f
) ;end progn for crosssections
) ;end if for wcmatch
) ;END PROGN
(progn
(initdia)
(command "_.PLOT")
) ;end progn
) ;END IF
(*error* "") ; reset sysvars
) ;end defun
Any suggestions to simplify the code would also be appreciated, I kind of get lost in the ()
Re: Check if Custom Drawing Property exists
I know this thread is kind of old, but I never really got a reply that worked. everything I have tried returns an error and stops processing, even the vl-catch-all-apply and error-p commands. I would like to have the program continue to process if the custom drawing property doesnt exist, maybe just display a message that the property doesnt exist. It isnt an issue in new drawings, just older drawing that havent had the custom drawing property added.
Not sure if this will work, but it is a shot. I renamed a couple of your variables so you will need to adjust this snippet to fit your needs.
In place of this code:
Try this:
(setq KeyName "PLOTFILE"
KeyCount 0
KeyValue nil
(while (and (null KeyValue)
(< KeyCount (vla-NumCustomInfo DwgProps))
(vla-GetCustomByIndex
dwgprops
KeyCount
'TempKeyName
'TempKeyValue
(if (= TempKeyName KeyName)
(setq KeyValue TempKeyValue)
(setq KeyCount (1+ KeyCount))
You need to find out if the Key is set. If it is not set you would get the error you describe. Instead of looking for the Key by it's name, I cycled through the custom keys.
You may just be able to add this to the end of my above code to adjust the values to the appropriate variable name.
(setq ext KeyValue)
that worked great, it wasnt a big issue, but any good code doesnt produce an error to the command line, and now, mine doesnt. Thanks again.
