Re: AutoCAD 2010 Plant 3D
If you are using ISOGEN for your isometric output, then that's all you'll get.
Generally, ISOGEN was designed for generating piping fabrication drawings for each pipeline. I first started using ISOGEN back when it was as sub-module of something called ISOPEDAC and required input through IBM key-punch cards!
If you need a isometric view of your entire design then you'll need to create a 3D view inside of AutoCAD in the usual manner.
Hope this helps!
There is a discussion group for Plant 3D within the Autodesk Discussion groups which may help you.
Hi there,
I'm moving this thread from the AutoCAD forum to the new Plant 3D forum, as I believe it will be better served here. Thanks.
