RE: all mixed up licenses
You cannot have 4 AutoCAD on 4 PC's and 4 Inventors on 4 other PC's.
Hi
Check out the following Technical Document on the Autodesk web site under the Knowledge Base section (this one might be a little more relevant seeing as the Autodesk® License Manager went through changes with the introduction of AutoCAD 2002) -
ID: TS67112 - Reserve network licenses for users or hosts
Have a good one, Mike
All, I have more information on my little problem!
Our cad support vendor says that if you install autocad 2005/ mechdesktop from the inventor 9 pro disk, then it will take an inventor pro licence! If you install AutoCAD 2005/ mechdesktop from the inventor 9 standard disk, then it will take an inventor standard licence! Because my seat was installed from the pro disk, I open up 2005 and the pro licence comes with me! I am not popular at the moment.
