Re: ROOM TAGS NOT SHOWING
It could be a lot of things,
but first thing to look at is your VG settings, and/or if you're using view templates (which is recommended), check in that to see if those or checked as not visible, or not visible in the linked model, or filtered out with worksets or whatever.
so, i was able to finally see them, but im not sure why this is happening.
the views are all set by view templates, if in my domestic view, i go into the V/G overides worksets, and change the mechanical from hide to show, i can see all the room tags i have tried to create. the main floor plan is set by shared levels and grids. so why are the room tags going in under mechanical while in my plumbing ones?
