PSELECT P windows 10
Hello,
Is anybody experiencing problems with the PSELECT P command?
autocad Arch installed on a windows 10
in windows 8 you select some objects on screen with mouse.
after deselecting you can you the PSELECT P command to re-select the last objects.
in windows 10 this doesn't work.
what works is first use the command SELECT to make a selection. with PSELECT P command you get the last objects then.
but when selecting object on screen with mouse the PSELECT P command doens't work or selects older selection sets.
Is this a bug?
Is anybody experiencing same problem?
Re: PSELECT P windows 10
It,s not a bug, it works ok for me.
See if some of the conditions mentioned in this post help. Is the Properties palette turned off?
after 3 months still having this same problem
also on another pc
properties palette is open
latest update from 09.2019 installed
can you confirm you are using Autocad Architecture, not having this problem with normal autocad or civil 3d
Is there any reason you're not using SELECT P?
